Chily
Q: {Reversed Scale} script can't work at control chart builder with mutiple Y Charts
I have one question about {Reversed Scale} script can't work at control chart builder with mutiple Y Charts.
It looks no issue on single Y control chart.
I built mutiple Y control charts and modified all charts Y scale to Reverse Order ,then save it to script to table.
But when I run the scrip, the Y Axis looks the same and never reversed.
Attach file is the table with script, could you help?
Is it a bug? How can I solve it? Thank you.
Control Chart Builder(
	Size( 534, 464 ),
	Show Two Shewhart Charts( 0 ),
	Test Excluded Subgroups( 1 ),
	Show Lower Control Limit( 0 ),
	Show Control Panel( 0 ),
	Variables(
		Subgroup( :"Month Year[MEASURE_DATE]"n ),
		Subgroup( :LOT_ID, Position( 1 ) ),
		Y( :P3, :P3H, :P3L, :P3UL )
	Chart(
		Points( Statistic( "Average" ), Box Plots( 1 ) ),
		Limits( Sigma( "Range" ), Show Lower Limit( 0 ), Show Upper Limit( 0 ) ),
		Process Capability Analysis(
			Overall Sigma Capability( 0 ),
			Nonconformance( 0 ),
			Within Sigma Capability( 0 ),
			Histogram( 1, Show Within Sigma Density( 0 ) )
		Dispatch( {}, "P3", ScaleBox, {Reversed Scale} ),
		Dispatch(
			{"P3 Limit Summaries", "Process Capability Analysis", "Histogram"},
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3H",
			ScaleBox,
			{Format( "Best", 10 ), Min( -0.494659722199707 ), Max( -0.7423333333 ), Inc( 0.05 ),
			Minor Ticks( 1 )}
		Dispatch(
			{"P3H Limit Summaries", "Process Capability Analysis", "Histogram"},
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3L",
			ScaleBox,
			{Format( "Best", 10 ), Min( -0.6705555556 ), Max( -0.975 ), Inc( 0.05 ), Minor Ticks( 1 )}
		Dispatch(
			{"P3L Limit Summaries", "Process Capability Analysis", "Histogram"},
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch( {}, "P3UL", ScaleBox, {Reversed Scale} ),
		Dispatch(
			{"P3UL Limit Summaries", "Process Capability Analysis", "Histogram"},
			"1",
			ScaleBox,
			{Reversed Scale}
Re: Q: {Reversed Scale} script can't work at control chart builder with mutiple Y Charts
This is a problem with JMP that has been corrected in 17.0.  If you upgrade to 17.0, your JSL will work as expected.
However, there is a workaround that will allow this to work in earlier versions of JMP.  If you send the dispatch commands separately, then this will work as expected in older versions of JMP.
obj=Control Chart Builder(
	Size( 534, 464 ),
	Variables(
	Chart(
	wait(1);
	obj<<
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3H",
			ScaleBox,
			Minor Ticks( 1 )}
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3L",
			ScaleBox,
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
	Size( 534, 464 ),
	Variables(
	Chart(
	wait(1);
	obj<<
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3H",
			ScaleBox,
			Minor Ticks( 1 )}
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"P3L",
			ScaleBox,
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
		Dispatch(
			"1",
			ScaleBox,
			{Reversed Scale}
Chily
Thank you tonya_mauldin,
It's great to know thank JMP17 had fix this bug
and thank you extra provide workaround solution for me!
Regards,Chily
