DanAlexander
Adding x number of days to a Character Date column (dd-Mon-YYYY)
I have a JSL script that periodically pulls data from an Access database.
The access database contains a date column "Available Date" with a dd-Mon-YYYY (E.g., 12-APR-2018) format. What I am trying to do, is create a new column "Target Date" in JMP that adds x number of days to the date in "Available Date" for each row.
For example: In the image below, the Target date is equal to Available date + 4 days. I am trying to automatically calculate the Target date based on the Available date. The number of days is based on the "Time (Months)" column.
This is what I've tried so far, which obviously does not work. I think I need to convert the "Available Date" column to a numeric data type, then add the number of days & convert back to Character?
dt << New Column("Target Date", "Character", "Nominal");
dt << For Each Row(
	IF (:"Time (Months)" <= 3, :"Target Date" = :"Available Date" + 4 ),
	IF (:"Time (Months)" > 3, :"Target Date" = :"Available Date" + 7 )
Re: Adding x number of days to a Character Date column (dd-Mon-YYYY)
Unless there is a real reason to keep the Target Date values as a character column, I suggest you convert it to a JMP Date column.
dt << new column( "Target Date", format( "ddmonyyyy") );
for each row(
	if( :"Time (Months)"n <= 3,
		:Target Date =
			Informat( :Available Date, "ddmonyyyy" ) + In Days( 4 ),
		:Target Date =
			Informat( :Available Date, "ddmonyyyy" ) + In Days( 7 )
It is very easy to convert the above output to character by the below modification
dt << new column( "Target Date", character );
for each row(
		:Target Date = format(
			"ddmonyyyy"
			Informat( :Available Date, "ddmonyyyy" ) + In Days( 7 ),
			"ddmonyyyy"
If the output format needs to be exactly as the input data format is, the following will get that accomplished
monthList = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP",
"OCT", "NOV", "DEC"};
for each row(
		temp = Informat( :Available Date, "ddmonyyyy" ) + In Days( 4 ),
		temp = Informat( :Available Date, "ddmonyyyy" ) + In Days( 7 )
	:Target Date = Substr( "0", Length( Char( Day( temp ) ) ) ) ||
	Char( Day( temp ) ) || "-" || monthList[Month( temp )] || "-" ||
	Char( Year( temp ) );
If you wanted to use a formula rather than the For Each Row, this would be for formula for the above output
monthList = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
If( :"Time (Months)"n <= 3,
Substr( "0", Length( Char( Day( temp ) ) ) ) || Char( Day( temp ) ) || "-" || monthList[Month( temp )] || "-" ||
dale_lehman
The attached table adds 4 days to your available date column to get the target date.  Steps:  change the data type for available date to numeric/continuous with appropriate date formatting; then use the Date Increment function to add 4 days to the available date, finally change the formatting for the resulting target date column to match what you used in the available date column.
One additional note - in your example, it looks like you added a week (7 days rather than 4).
for each row(
		:Target Date =
		:Target Date =
for each row(
			"ddmonyyyy"
			"ddmonyyyy"
for each row(
DanAlexander
This is excellent, exactly what I was trying to do - and so simple! Thank you for the help. I will leave it in the date format.
