katelyn
Adding Duplicate Rows
Quick question,
I am working on moving columns from one data table over to another.  The rows don't match up, the place where I am moving the columns has 4 times more rows.  Is there a way that I can duplicate every row three times to make the copying and pasting easier?
Thanks!
Re: Adding Duplicate Rows
Have you investigated the Tables > Join command? The default method to match rows but there is another option, Cartesian, to match every row in one table with every row in the other table. I can't tell from your description if this way will work but it is worth looking into.
See Help > Books > Using JMP > Reshape Data chapter > Join section.
Go to
     Tables==Concatinate
There you can specify to concatinate your current data table 3 times concat.GIFconcat.GIF
Roselle_Grant
This helped me... Thanks!
