Sandra
Add rows every x rows
Dear community, i've got a huge table and would like to add one row every 4 rows (4 rows data, adding 1 row, moving the rest of the data downwards, then adding 1 row after 4 rows of data aso).
I have no clue how to achieve that with a script. Can anyone kindly help me with this topic?
Re: Add rows every x rows
See Help > Scripting Index:
The << Add Rows message to the data table will do what you want. The optional After argument identifies the location, so you can space the insertions every 4 rows.
Use the For() function to iterate over the data table. The iteration will be easiest if you start at the end and insert on the way to the top. The insertions will each length the data table and complicate the counting if you start at the top.
Just to add to @Mark_Bailey suggestion, here is a real simple example
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
For(i=N Rows(dt),i>=1,i=i-4,
	dt << add rows(1, after(i))
jimloughlin
When I run the code, I get the following error:
Name Unresolved: after in access or evaluation of 'after' , after( i ) /*###*/argument is wrong type in access or evaluation of 'after' , after( i ) /*###*/
In the following script, error marked by /*###*/
For( i = N Rows( dt ), i >= 1, i = i - 4,
dt << add rows( 1, after( i ) /*###*/ )
Jim Loughlin
Loughlin Consulting
It works for me:
	dt << Add Rows( 1, After( i ) )
jimloughlin
I am running JMP13 but I don't think that is the cause of the issue.  Think I will contact tech support.
Jim Loughlin
Loughlin Consulting
I bet you are using JMP 13 or earlier.  The "After" capability was added in JMP 14.  Here is alternative way to do what you need
dt4 = New Table("Results");
For(i=1,i<=n rows(dt), i=i+3,
	dt<<select where(Row()>=i & Row()<=i+3);
	dtTemp = dt << subset(selected rows(1), selected cols(0));
	dt4 << concatenate(dtTemp, append to first table);
	dt4 << add rows(1);
	close( dtTemp, nosave );
jimloughlin
That did the trick.  Thanx.
Jim Loughlin
Loughlin Consulting
