Add a new column with a function similar to vlookup in Excel
I'm trying to figure out how to add a new column to a table that will populate with data dependent on other data in that row. We have several fermentations in a data frame. Each one has a blank value. I'd like to have the blank value from each fermentation in a new column so that I can subtract it from the treatment value. Also if there's a better way to do this than creating a new column that would be great too! Thanks.
Made up example data:
FermentationTreatmentValueFermentation Blank Value
A1986
A2736
ABlank66
B1845
B2865
BBlank55
Re: Add a new column with a function similar to vlookup in Excel
Most likely the Value column in your datatable isn't formatted as numeric (most likely a character).
Here is a script with example table that does work. Look at the left side for columns and their modeling types, Value is continuous (you cannot have data type = character, modeling type = continuous in JMP (you could have numeric nominal though which you cannot see directly from the modeling types...).
dt = New Table("Untitled",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("Fermentation", Character, "Nominal", Set Values({"A", "A", "A", "B", "B", "B"})),
	New Column("Treatment",
		Character(16),
		"Nominal",
		Set Values({"1", "2", "Blank", "1", "2", "Blank"})
	New Column("Value",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([98, 73, 6, 84, 86, 5])
	New Column("Fermentation Blank Value",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([6, 6, 6, 5, 5, 5])
dt << New Column("Val", Numeric, Continuous, Formula(
	Col Sum(If(:Treatment == "Blank", :Value, .), :Fermentation)
dale_lehman
Is the "Value" when Treatment = Blank always less than the Value when Treatment is not Blank?  If so, you can just use the ColMin function, by Treatment.  If not, I suppose a somewhat clumsy way to do something similar is first create a column that makes Treatment not equal to Blank = 1 and Treatment = Blank equal to zero, and then use the ColMin By approach.
dale_lehman
That should have been by Fermentation, not by Treatment.
Where would you have the value if not in a new column?
Here is one formula how you could add it as a new column
When I try this expression I get an error saying
Expecting numeric column in access or evaluation of 'Col Sum', Col Sum/*###*/IF(:Treatment == "Blank", :Value,.):Fermentation)
The column "Value" is numeric continuous, so I'm not sure what part of the expression it doesn't like
	Add Rows(6),
		Character(16),
		"Nominal",
	New Column("Value",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Numeric,
		"Continuous",
		Format("Best", 12),
