Azim
Add File Name and Date in Import Settings
I would like some input on how to include adding File Name and File Date in import settings.
In typical Multiple File Import, we have
<<Set Add File Name Column( 1 ),
<<Set Add File Size Column( 0 ),
<<Set Add File Date Column( 1 ),
However, this will not work in my case. So I tried using New Column () function, but it gives empty columns or no column "Source File" at all.
 For(i = 1, i <= N Items(selectedPaths), i++,
        path = selectedPaths[i];
        dt = Open(
            path,
            Headers(1),
            Column Names Start(1),
            Data Starts(2),
            End Of Field(","),
            Invisible
        dt << New Column("Source File",
            Character,
            Set Values(Repeat(path, N Rows(dt)))
I guess it should be included amongst dt = Open () setting but I do not know what to put there for File Name and File Date Columns.
Re: Add File Name and Date in Import Settings
Is there a specific reason why Multiple File Import cannot be used? You can find syntax for Open() from JSL Syntax reference Open(path, <arguments>) or from scripting guide but I would suggest you do it once manually from JMP using the interactive open and then copy+modify the script JMP provides you with.
A couple of comments
Using your JSL, you can change your code very simply to add in the Path
            Character,
            Set Each Value(path)
Also, if you use the Modal option on your New Windows you do not have to use your "Done" methodology.  Modal windows stop the processing beyond the New Window, until the window is closed
// Step 1: Prompt user to choose between File or Folder
uploadType = "";
done = 0;
nw = New Window("Select Upload Type",modal,
    Panel Box("Choose Upload Type",
        cb = Combo Box({"File", "Folder"}),
        Button Box("OK",
            uploadType = cb << Get Selected;;
