Gabogom
Weibull DOE (Regression)
Hello Everybody, recently im working using RSM for Weibull Response, I did the model using Fit Parametric Survival and I have parameters estimates results.
The issue is about, the parameters for polynomial regression is based on codec units (-1,1).
There some way to get this parameters on uncoded units (reals levels), on this kind of reports?
Attached small pic about the results/
statman
Re: Weibull DOE (Regression)
Re-run the analysis using the actual levels of the factors.
