Add Control limits to each group in a variability chart
Is it possible to add each parameter its own control limits?
Many thanks,
A.
Re: Add Control limits to each group in a variability chart
Merging Y-axis
Select multiple items from the column selector and drop them to Y-axis if you start on empty graph. Or drop them to correct location in the graph Essential Graphing > Graph Builder > Work with Axes > Merge Variables on an Axis
Multiple plot
Hold Shift while you click Line chart from the different plotting types. You can also do it by right clicking and selecting Add or by dragging and dropping them to the graph
Essential Graphing > Graph Builder > How to Use Graph Builder > About the Graph Builder Window
Essential Graphing > Graph Builder > Element Types and Options
As you can maybe guess, this is a good documentation to read regarding graphing in JMP Essential Graphing
Yes it is possible, how to do it depends on your data. Can you provide an example of the data and a script to create the plot you have?
I simply use variability chart of graph builder.
basically, each subject has production results and validation results. Each of the subjects has its own control limits -LCL and UCL.
Thank you,
A.
Where are those limits stored? In the same table as measurement results with each group having their own limit? Different specification table? In some other data structure?
I assume they are stored in the same table in their own columns.
You can do something like this fairly easily in graph builder by disabling/enabling correct variables (columns) for two separate plots while having the value + limit columns in Y-axis
If you were to move groups to X-group instead of X-axis you can get this
or you can move the X Group edge to bottom
Thank you.
How do you add both points and line graphs on the same graph?
and how do I make on Y axis for all 3 variables?
Thanks again,
A.
Merging Y-axis
Multiple plot
