Ok, I'm with you on your first point. I can see how it would take a long time for these methods to be updated and become mainstream.
Regarding this comment, "if one used a traditional MANOVA for a repeated measures analysis, the subject is a random effect." Can I ask my question a different way perhaps? If I use the JMP add-in for full factorial repeated measures ANOVA to do my analysis (as I did at the beginning of this thread), would subject be treated as a fixed or random effect?
If fixed, then I understand your comment about this method being "behind the times." If random, then what is the difference between what the add-in does and running the analysis using this method (
http://www.jmp.com/support/notes/30/584.html) with the univariate split-plot approach? The results come out a bit different. My only conclusion is that the add-in treats subject as a fixed effect and the second method treats it as random.
I am also a bit thrown by JMP's use of the term "MANOVA" as I always thought of MANOVA as involving two dependent variables (
http://online.sfsu.edu/efc/classes/biol710/mā¦), whereas I only have one DV. I take it JMP calls it MANOVA but if you enter only on DV, then it really is an ANOVA you are running?
Sorry for the long string of questions. I hope this thread will be useful to someone with the same questions as me in the future. And I am learning a lot in the process!
