claude_bellavan
A JSL script for moving columns to original order?
Is there a way to script this menu command: Columns/Reorder Columns/Original Order .
In the JSL manual, I found :
  • dt<<Reorder By Name
  • dt<<Reorder By Data Type
  • dt<<Reorder By Modeling Type
In need to restore the column order to orignal order before Data Table update and reorder it by name after the update.
Thanks,
Claude B.
ms
Super User (Alumni) ms
Re: A JSL script for moving columns to original order?
It's simply
dt << Original Order;
ian_jmp
Level X
It's unusual to have a menu command without a JSL equivalent. But if it's not there (I didn't check), you can make use of 'MainMenu()':
Wait(3);
dt << ReorderByName;
Wait(3);
dt = CurrentDataTable();
MainMenu("Cols:Reorder Columns:Original Order");
ms
It's simply
ian_jmp
Level X
The best place to check out this kind of stuff is 'Help > Scripting Index', which usually has useful examples too, should you need them:
Clearly I need to use it more often myself . . .
claude_bellavan
Thank you very much!
Both responses will be very useful in the future.
Claude
