Alicia
3d surface plot - change from cube shape to cuboid
Hi there,
Is there any way to change the graph space of the 3d surface plot from a cube to a cuboid?
I want to visualise a long surface so the cube makes the plot look disproportional.
Many thanks
frank_wang
Re: 3d surface plot - change from cube shape to cuboid
Hi
My JMP version is pro 15.1. No related setting in kinds of 3D plot.
Check 'Properties' of 3D plot. No parameter text edit box about 'Frame Size'.
May be you can post in JMP wish list. Good luck.
心若止水
