Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
I'm trying to recreate this GC metric chart from Picard in JMP but am having trouble figuring out how to get 3 different Y-axes that all have different elements. Here is the graph I am trying to make:
This is as far as I have gotten. I added the base quality to the y axis and then moved it to the right to get two Y-axes but can't figure out how to add in the red histogram as well.
I've attached the data with the script I have so far. I'd prefer a non-coding answer if possible and am using JMP 19. Thanks so much for your help!
