Markus Schafheutle, Consultant, Business Consulting
Laura Castro-Schilo, JMP Senior Research Statistician Developer, SAS
Christopher Gotwalt, JMP Director of Statistical R&D, SAS
We describe a case study for modeling manufacturing data from a chemical process. The goal of the research was to identify optimal settings for the controllable factors in the manufacturing process, such that quality of the product was kept high while minimizing costs. We used structural equation modeling (SEM) to fit multivariate time series models that captured the complexity of the multivariate associations between the numerous process variables. Using the model-implied covariance matrix from SEM, we then created a Prediction Profiler that enabled estimation of optimal settings for controllable factors. Results were validated by domain experts and by comparing predictions against those of a thermodynamic model. After successful validation, the SEM and Profiler results were tested in the chemical plant with positive outcomes; the optimized predicted settings pointed in the correct direction for optimizing quality and cost. We conclude by outlining the challenges in modeling these data with methodology that is often used in social and behavioral sciences, rather than in engineering.
Speaker |
Transcript |
Hello, I'm Chris Gotwalt and | |
today I'm going to be | |
presenting with Markus Schafheutle | |
and Laura Castro-Schilo | |
on an industrial application of | |
structural equations models, or | |
SEM. This talk showcases one of | |
the things I enjoy most about | |
my work with JMP. In JMP | |
statistical development, we have a | |
bird's eye view of what is | |
happening in data analysis | |
across many fields, which gives | |
us the opportunity to cross | |
fertilize best practices across | |
disciplines. | |
In JMP Pro 15, we added a new | |
structural equations modeling | |
platform. This is the dominant | |
data analytic framework in a | |
lot of social sciences because | |
it flexibly models complex | |
relationships in multivariant | |
settings. One of the key | |
features is that variables may | |
be used as both regressors and | |
responses at the same time as a | |
part of the same model. | |
Furthermore, it occurred to me | |
that with these complicated | |
models they are represented with | |
diagrams that, at least on the | |
surface, look like diagrams | |
representing manufacturing | |
processes. I wasn't the only one | |
to make this connection. Markus, | |
who was working with a | |
chemical company, thought the | |
same thing. He was working on a | |
problem with a chemical company | |
with a two column twin | |
distillation manufacturing | |
process where they wanted to | |
minimize energy costs which were | |
largely going to steam | |
production, while still making | |
product that stayed within | |
specification. He reached out to | |
his JMP sales engineer, | |
Martin Demel, who then connected | |
Markus to Laura and I. | |
We had a series of meetings | |
where he showed and described | |
the data, the problem and the | |
goals of the company. We were | |
able to model the data | |
remarkably well. Our model was | |
validated by sharing the results | |
as communicated with the JMP | |
profiler to the company's | |
internal experts and then with | |
the first principle simulator | |
and then with new physical data | |
from the plant. This was a clear | |
success as a data science | |
project. However, I would like | |
to add a caveat. The success | |
required the joint effort of | |
Laura, who is a top tier expert | |
in structural equations | |
modeling. Prior to joining JMP, | |
she was faculty in quantitative | |
psychology at the University of | |
North Carolina, Chapel Hill, one | |
of the top departments in the | |
US. She is also the inventor of | |
the SEM platform in JMP Pro. | |
This exercise was challenging | |
even for her. She had to write a | |
JSL program that itself wrote | |
a JSL program that specified | |
this model, for example. | |
The model we fit was perhaps | |
the largest and most | |
sophisticated SEM model of all | |
time. I want to call out the | |
truly outstanding and | |
groundbreaking work that | |
Laura's done both with the SEM | |
platform generally and in this | |
case study in particular. Now | |
I'm going to hand it over to | |
Markus, who is going to give | |
background to the problem the | |
customer wanted to solve, then | |
Laura is going to talk about | |
SEM and her model for this | |
problem. I'll do a brief | |
discussion of how we set up the | |
profiler and then Markus will | |
wrap up and talk about the | |
takeaways from the project and | |
the actions that the customer | |
took based on our results. | |
Thank you, Chris, for the | |
introduction. | |
Before I start with the problem, | |
I want to make you familiar with | |
the principles of distillation. | |
Distillation is a process which | |
separates a mixture of liquids | |
most of the time and separates | |
them into their individual | |
components. So how does this | |
work? Here, you see a schematic | |
view of a lab distillation | |
equipment. You see here is a | |
flask where the crude mixture, | |
which has to be separated, is | |
inside. You heat this up, here | |
in this case, with an oil bath | |
and stir it and then it starts | |
boiling. So the lowest boiling | |
material starts first and then the | |
vapor goes up here and pauses | |
here the thermometer to reach | |
the boiling temperature and then | |
further goes into these cooler | |
here where it condensates and | |
then the condensates drop here | |
into the other little flask. | |
So as I said, it's built | |
from...for separating a mixture | |
of liquids with different | |
boiling points, and those are | |
separated by boiling point. | |
For example, everybody knows | |
that perhaps if you want to make | |
schnapps from a mash, you just | |
make the mash inside of this | |
flask, heat it up, and then you | |
distill the alcohol over here | |
and get the schnapps. | |
As it looks very simple | |
here in the lab, in the | |
industry it's a bit more | |
complicated. Because let's | |
say the equipment is not | |
only bigger but more | |
complex and mainly because | |
of of the engineering part | |
of of the story. | |
So in this study, the | |
distillation was not done | |
batchwise as you've seen before, | |
but in a continuous manner. This | |
means the crude mixture is | |
pumped somewhere in the middle of | |
the column and then the low | |
boiling material goes up as a | |
vapor to the top of the column | |
and there it leaves the column | |
and the other higher boiling | |
material flows downward and | |
leaves the column on the bottom. | |
And to make it a bit more | |
complicated, in our case the | |
bottom stream is then pumped | |
into a second column and | |
distilled again, so to | |
separate another material | |
from the main..from... | |
from the residual stuff. So | |
actually we separated the | |
original crude mixture into | |
three parts | Distillate 1, |
Distillate 2 and what's | |
left, then the bottom stream | |
of the second still. | |
And to make it even more | |
complex, we used the heat of the | |
distillate of this second column | |
to heat the first column in | |
order to save energy for this. | |
So in a schematic view, | |
this looks like this. | |
Here you have Still 1 and | |
there's Still 2. And here we | |
have the raw material mix which | |
is actually assembly of | |
distillates from the | |
manufacturing and what we want | |
to do is to separate the value | |
material from the rest. So we | |
pumped this crude mix into the | |
first stills. As I said somewhere | |
in the middle it separates in | |
the low boiling point, which is the | |
first value material we want to | |
have, and the rest leaves the | |
first still on the bottom. Then | |
it's stored immediately here in | |
a tank and then from here it's | |
pumped again into the second | |
still, again somewhere in the | |
middle, and it separates into | |
the second value material and | |
away stream, which was then | |
redeposited. To heat the stuff, | |
we start on this side because | |
this is the higher boiling | |
material, so we need higher | |
temperatures and this means also | |
more energy. So we pump in the | |
steam here, heat this still here, | |
and the material leaving here on | |
the top has the temperature of | |
the boiling of this material, so | |
we used the residual heat to | |
heat the first still. And if | |
there's a little gap between | |
what's coming up from here and | |
what we need for for | |
distillation here in the first | |
still, we can add a little | |
extra steam to keep | |
everything running. | |
So this is a very high level | |
view of the things, and if you | |
want to go a bit more into the | |
details, here it's kind of the | |
same picture. But here I show | |
you with all the different tags | |
which we have here for all the | |
readouts and quality control and | |
temperature control and so on | |
and so forth. So what you see | |
here? We start here, for feed one | |
into the first still. | |
And then we separate into the top | |
stream where we control the | |
density, which is a quality | |
characteristic. And in the | |
bottom stream, the bottom stream | |
goes in this intermediate tank. | |
And then from here it's fitted | |
again into the second still and | |
also and separated here in the | |
bottom stream for top stream. | |
And again we are testing here | |
density for quality control. | |
Here also we add the steam to | |
heat all these things up and | |
the top flow then goes via heat | |
exchanger into the first still | |
and heat that up again. And here | |
we have the possibility to add | |
some extra steam to have | |
everything in balance here. | |
So what we see is on a local | |
basis you have a lot of | |
correlation, so this is done | |
here with the color code of the | |
arrows. So for example, the feed | |
here together with the feed | |
density, which is a measure for | |
the composition here of this | |
feed. So together with these two | |
are defining the top stream and | |
quality here, and that | |
bottom stream more or less. So you | |
have some local predictions. Also | |
over here the material going in | |
here and here defines stuff over | |
here. But if you want to have a | |
total description of the entire | |
equipment, then it gets tricky | |
because you can do local least square | |
correlations here. You can do it | |
here. You can do it separately | |
for the steam or also here. But | |
as you see, we have a start of | |
the mass stream coming here, going | |
through first still, through the | |
second still, to here and we have | |
an energy stream which starts | |
more or less here, going through | |
here via the heat exchanger also | |
down here. So it's a kind of a | |
circuit, which we have here, and | |
all these things are correlating | |
more or less in a kind | |
of circuit and this gives gives | |
us the difficulty that we | |
actually didn't know what the Xs | |
and the Ys were. | |
And that was the reason where we | |
started to think about other | |
possibilities to model this. | |
So the target for this study was | |
to find the optimal flow and | |
steam settings for all these | |
varying incoming factors | |
here, and in a way that we | |
are able to stay everything | |
in spec. So the distillate | |
quality should stay in spec but | |
also internal operational | |
specs and also the spec for | |
the final waste stream. | |
And the most interesting part, | |
at least money | |
wise, we want to minimize | |
the consumption of the | |
speed...sorry, of the steam. | |
So what we actually needed | |
was first of all, a good model | |
which describes this and that | |
was the point where Laura came | |
into the game here and developed | |
this structural equation model. | |
And we also need the kind of | |
profiler which enables us to | |
figure out what are the best | |
settings, the optimal settings | |
for all these incoming | |
variations, which we may have | |
here in order to stay within all | |
these specs. And that was the | |
point where Chris came in, | |
building on the model from Laura, | |
a profiler, which we can use for | |
doing all the predictions we | |
need. So now I want to pass | |
over to Laura to describe the | |
model she built from this | |
data here. Laura, please. | |
Thank you, Markus. I'm Laura | |
Castro-Schilo and I'm going | |
to tell you about the steps | |
we followed to model the | |
distillation process using | |
the structural equation | |
models platform. | |
So when Markus first came and | |
talked to us about his project, | |
there were three specific | |
features that made me realize | |
that SEM would be a good tool | |
for him. The first is that | |
there was a very specific | |
theory of how the processes | |
affect each other, and we saw | |
that on the diagram that he | |
showed. | |
An important feature of that | |
diagram is that all variables | |
had dual roles. In other words, | |
you can see that arrows point at | |
the nodes of the diagram, but | |
those nodes also point at other | |
variables, so there wasn't a | |
clear distinction between what | |
was an input and what was an | |
output. Rather, variables had | |
both of those roles. | |
Lastly, it was important to | |
realize that we were dealing | |
with processes that were | |
measured repeatedly. In other | |
words, we had time series data | |
and so all of these features | |
made me realize that SEM would | |
be a good tool for Markus. Now, | |
if you're not familiar with SEM, | |
might wonder why. SEM is a very | |
general framework that affords | |
lots of flexibility for dealing | |
with these types of problems. | |
I've listed in this slide a | |
number of different features | |
that make SEM a good tool, but | |
since we're not going to be able | |
to go through all of these, I | |
also included a link where you | |
can go with learn more about SEM | |
if you're interested. Now I'm | |
going to focus on two of the | |
points I have here. The first | |
is that SEM allows us to test | |
theories of multivariate | |
relations among variables, | |
which was exactly what Markus | |
wanted to do. | |
Also, there are very useful | |
tools in SEM called path | |
diagrams. These diagrams are | |
very intuitive and they | |
represent the statistical models | |
that we're fitting. | |
So let's talk about that point a | |
little more. Here is an example | |
of a path diagram that we could | |
draw in the SEM platform to | |
represent a simple linear | |
regression, and the diagram is | |
drawn with very specific | |
features. For example, we're | |
using rectangles to represent | |
the variables that we have | |
measured. Here, it's X and Y. We | |
also have a one-headed arrow to | |
represent regression effects. And | |
notice the double-headed arrows | |
that start and end on the same | |
variables represent variances. | |
Now, if these were to start and | |
end on a different variable, | |
those double-headed arrows would | |
then represent a covariance. In | |
this case, we just have the | |
variance of X and the residual | |
variance of Y, which is the part | |
that's not explained by the | |
prediction of X. | |
So this is the path diagram | |
representation of a simple | |
linear regression. But of course | |
we could also look at the | |
equations that are represented | |
by that diagram. And notice that | |
for Y, this equation is that of | |
simply a linear regression. And | |
I've omitted here the means and | |
intercepts just for simplicity. | |
It's important to note that | |
all of the parameters in | |
the equations are | |
represented in the path | |
diagram, so these diagrams | |
really do convey the | |
precise statistical model | |
Now in SEM, the diagrams or | |
models that we specify imply a | |
very specific covariance | |
structure. This is the | |
covariance structure that we | |
would expect given the simple | |
linear regression model. So you | |
can see we have epsilon X as the | |
variance of X. We also have the | |
variance of Y, which is a | |
function of both the variance of | |
X and the residual variance of | |
Y, and we also have an | |
expression for the covariance of | |
X and Y. And generally speaking, the | |
way that model fit is assessed | |
in SEM is by comparing the model | |
implied covariance structure to | |
the actual observed sample | |
covariance of the data, and if | |
these two are fairly close to | |
each other, we would then say | |
that the model fits very well. | |
So a number of different models | |
can be fit in SEM. | |
And today our focus is | |
going to be specifically | |
on time series models. | |
When we talk about time series, | |
we're speaking specifically about | |
a collection of data where there | |
is dependence on previous data | |
points, and these data are | |
usually collected across equally | |
spaced time intervals. | |
And the way that time series | |
analysis deals with the | |
dependencies in the data is by | |
regressing on the past. So one | |
type of these models are called | |
autoregressive processes or | |
ARP. And you can see here, where | |
Y represents a process that is | |
measured at time T, the auto | |
regressive models consist on | |
regressing that process on | |
previous observations of that | |
process up to time T minus P. | |
So if we're talking | |
specifically about an | |
autoregressive one process, | |
then you can see we have the | |
process YT regressed on its | |
immediately adjacent past YT | |
minus one. | |
And the way that we would | |
implement this in SEM is simply | |
by specifying, as we saw before, | |
the regression of YT on YT minus | |
one. So notice that here the | |
regression equation is very | |
similar to what we saw in | |
the previous slide, and so | |
it's no surprise that the | |
path diagram looks the same. | |
And we can extend this AR(1) | |
model to one that includes two | |
lags, in other words, an | |
autoregressive of order two. And | |
here we see we have the process | |
YT that is being regressed on | |
both T minus 1 and T minus 2. | |
And if we look at the path | |
diagram that represents that | |
model, we see that we have an | |
explicit representation for the | |
process at the current time, but | |
also at the lag one and lag two. | |
A very specific aspect of this | |
diagram is that the paths for | |
adjacent time points are set to | |
be equal to each other, and this | |
is an important part of the | |
specification that allows us to | |
specify the model correctly. So | |
notice here we're using beta 1 | |
to represent this lag 1 | |
effects and we also have to | |
set equality constraints on | |
the residual variances. | |
Lastly, we also have the effect | |
of YT minus 2 as it's | |
predicting YT, and so here's the | |
lag 2 effects. | |
Now all of these models are | |
univariate time series models, | |
and you can fit them using the | |
structural equation modeling | |
platform in JMP or you could | |
also use the time series | |
platform that we have available. | |
However, the problem we were | |
dealing with with Markus' data | |
require more complexity. It | |
required us to look at | |
multivariate time series models | |
and a type of these models are | |
called vector autoregressive | |
models. And what I'd like to | |
show you is one of these models | |
of order two. | |
So we have a process for X and | |
another one for Y, and the same | |
autoregressive effects that we | |
saw before are included here. | |
Notice we have our equality | |
constraints which are really | |
important for proper | |
specification. But we also have | |
the cross lagged effects which | |
tell us how the processes | |
influence each other. And notice | |
here gamma 1 and gamma 1 and | |
also gamma 3, gamma 3, | |
suggesting here that we have to | |
put equality constraints on | |
those lag 1 effects across | |
processes. | |
We also have to incorporate the | |
covariances across the processes | |
so we have their covariance at | |
time T minus 2. But we also have | |
the residual covariances at time | |
T minus 1 and T and notice these | |
have to have equality | |
constraints again to have proper | |
specification. So I'm going | |
to show you in this video how | |
we would fit a bivariate time | |
series model just like the | |
one I showed you, using JMP | |
Pro. We're going to start by | |
manipulating our data so that | |
they're ready for SEM. First, | |
we standardize these two | |
processes because they are in | |
very different scales. | |
Then we create lagged variables | |
to represent explicitly the time | |
points prior to time T. So we're | |
going to have | |
We launched the SEM platform and | |
we're going to input the Xs | |
then the Ys so that it's | |
easier to specify our models. | |
And now I sped up the video | |
so that you can quickly see | |
how the model is specified. | |
Here we're adding the | |
cross lagged effects | |
for lag 1. | |
And then directly using the | |
interactivity of the diagram, we | |
add the lag 2 effects. | |
And what remains is to | |
specify all the equality | |
constraints that are required | |
for these models within | |
process and across processes. | |
We name our model. | |
And lastly, we're | |
going to run it. | |
As you could see, even just a | |
bivariate time series model that | |
only incorporates two processes | |
requires a number of equality | |
constraints and nuances in the | |
specification that make it | |
relatively challenging. However, | |
in the case of the distillation | |
process data, we had a lot more | |
than two processes. We were | |
actually dealing with 26 of | |
these processes and in total we | |
had about 45,000 | |
measurements, which were taken | |
at 10 minute intervals. | |
And so our first approach was | |
to explore the univariate | |
time series models using the | |
time series platform in JMP. | |
And when we did this, we | |
realized that for most | |
processes an AR(1) or AR(2) | |
model fit best, and so this | |
made me realize that really | |
at the very least we needed | |
to fit multivariate models in | |
SEM that incorporated at | |
least two lags. | |
We also had to follow a number | |
of preprocessing steps for | |
getting the data ready into SEM. | |
On the one hand, we had a lot of | |
missing data, and even though | |
SEM can handle missing data just | |
fine, with models that are as | |
complex as these ones, it became | |
computationally very very | |
intensive. And so we decided to | |
select a subset of data where we | |
had complete data for all of the | |
processes and that left us with | |
about 13,000 observations. | |
Also, as we saw in the video, we | |
had large scale differences | |
across the processes, so we had | |
to standardize all of them. And | |
lastly we created lag variables | |
to make sure that we could | |
specify the models in SEM. | |
Now for model specification, | |
equality constraints in | |
particular are very very big | |
challenge because it would take | |
a lot of time to specify them | |
manually and it would be, of | |
course, tedious and error-prone. | |
So our approach for dealing with | |
this was to generate a JSL | |
script that would then generate | |
another JSL script for launching | |
the SEM platform. | |
And what you see here is the | |
final model that we fit in the | |
platform and thankfully, after | |
estimating this model, we are | |
able to obtain a covariance | |
structure that is implied by the | |
model and that was the piece of | |
information that I could pass | |
over to Chris Gotwalt, who | |
then used the information from | |
that matrix in order to create a | |
profiler that Markus could use | |
for his purposes. | |
So Chris, why don't you tell us | |
how you created that profiler? | |
Thank you, Laura. Now I'm going | |
to show the highlights of how | |
I was able to take the model | |
results and turn them into a | |
profiler that the company | |
could easily work with. | |
So Laura ran her model on the | |
standardized data and sent me a | |
table containing the same model | |
intercepts and she also included | |
the original means and standard | |
deviations that were used to | |
standardize the data. On the | |
right we have the sim model | |
implied covariance matrix, which | |
includes the covariances between | |
the present values and the | |
lagged values from the immediate | |
past. This information describes | |
how all the variables relate to | |
one another. In this form, | |
though the model is not ready to | |
be used for prediction. To see | |
how certain variables change | |
as a function of others, we have | |
to use this information to | |
derive the conditional | |
distribution of the response | |
variables, given the variables | |
that we want to use as inputs. | |
So essentially we need the | |
conditional mean of the | |
responses given the inputs. So | |
to do that, we need to implement | |
this formula right here. | |
And to do that, we use the SWEEP | |
Operator in JSL, the SWEEP | |
Operator is a mathematical tool | |
that was created by SAS CEO and | |
co-founder Jim Goodnight. It's | |
was published in the American | |
Statistician in 1979. The SWEEP | |
Operator is probably the single | |
most important contribution to | |
computational statistics in the | |
last 100 years. Most JMP users | |
don't know that the SWEEP | |
Operator is used by every single | |
JMP statistical platform in | |
many ways. We use it for matrix | |
inversion, the calculations that | |
sums of squares and also can be | |
exploited as simple and elegant | |
way to compute conditional | |
distributions if you know | |
how to use it properly. | |
I created a table with columns | |
for all the variables. The two | |
rows in the table are the | |
minimums and maximums of the | |
original data, which lets the | |
profiler know how to set up the | |
ranges. I added formula columns | |
for the response variables using | |
the swept version of the | |
variance matrix from Laura's | |
model and put those formulas | |
into the back here in the data | |
table or the far right. | |
Here's what one of the formulas | |
looked like. I pulled in the | |
results from the analysis as | |
matrices. Laura's model included | |
the estimated covariance between | |
the current Ys in the last two | |
preceding values because it was | |
a large multivariate | |
autoregressive model of order 2. | |
Predicting the present by | |
controlling the two previous | |
values of the input variables | |
was going to be very cumbersome | |
to operationalize. So I made | |
a simplifying assumption that | |
these two values were to be | |
the same, which collapsed the | |
model into a form that was | |
easier to use. To do this, I | |
simply use the same column | |
label when I was addressing | |
into the lag one, and | |
lag two entries for term. | |
Without machinery in place, | |
I created a profiler for the | |
response columns of | |
interest. I set up | |
desirability functions that | |
reflected the company's | |
goals. So they wanted to | |
match a target on on | |
A2TopTemp, maximize A2BotTemp, | |
and so on, ultimately | |
wanting to minimize the sum | |
of the steam that came out | |
of the two columns. | |
So you can lock certain | |
variables in the profiler by | |
control clicking on a pain. The | |
lock variables will have their | |
value drawn via a solid red | |
line, and then once we've done | |
that we can enter values for | |
them, and when we run the | |
optimizer or maximize | |
desirability, the locked | |
variables will be held fixed. | |
This way we find settings of the | |
variables that we can control | |
that keep the product being made | |
to specification while | |
minimizing energy costs. | |
It's fair to say that it would | |
be difficult for someone else to | |
repeat Laura's modeling approach | |
on a new problem, and it would | |
be difficult for another person | |
to set up a profiler like I did | |
here. If enough people see this | |
presentation and want us to add a | |
platform that makes this kind of | |
analysis easier in the future, | |
you should let us know by | |
reaching out to Technical | |
Support via support@JMP.com. | |
Now I'm going to hand it back | |
over to Markus who will talk | |
about what the customer did with | |
the model and our conclusions. | |
Thank you, Chris. | |
So with the prediction Profiler, | |
which Chris just presented, we | |
used that to, let's say, make a | |
predictive landscape, which | |
makes us understanding how | |
the best settings should be in | |
order to achieve all the | |
necessary quality specs. And so | |
what the three factors which | |
are, let's say, are varying with | |
limited extent to our influence, | |
and what's the | |
feed for the Still 1 and the | |
feed for the Still 2 and also | |
the quality or the composition | |
of the feed into one. | |
And what we've turned out as in | |
their model as well, is the | |
cooling water temperature was | |
also playing an important role | |
in this scenario. All the other | |
variables are of smaller importance | |
so that we neglected them in | |
this first approach. | |
Here you see the landscape. | |
It's kind of a variability | |
chart, so to say, so we have | |
here the feed density for the | |
Still 1, the feed into Still 1 | |
and the feed into Still 2 | |
and all possible combinations, | |
more or less. And here you see then | |
the settings which are predicted | |
to be best in order to stay | |
within the specifications. And | |
here are some of these I have | |
specifications as well, so we | |
have to stay inside them. | |
So it's, for example, it's the | |
steam flow for Still 2, the | |
reflux there, the boiler up and | |
the same things for the | |
Still 1. And here on the right | |
side, you see the | |
predicted outcomes, so the | |
quality specs, so to say. So the | |
temperature of the top flow in | |
Still 1 that the density | |
of the distillate, the density | |
of the distillate of Still 2, | |
and so on and so forth. So what | |
you see is here, if you have a | |
look here on the desirability, | |
which is the bottom row here, | |
there's big areas where | |
we cannot really achieve a good | |
performance of our system. And if | |
you have a look into the details | |
you see, OK, here we are off spec, | |
here we are off spec, here on | |
some points, we are off spec, and so on | |
and so forth. But what else it sees | |
is that this in spec/off spec thing | |
is also governed not only by | |
these three components down | |
here, but also by the river | |
temperature, and for the moment | |
it's highlighted the lowest | |
river temperature; it's 1 | |
degree. So this you see here | |
with it, we are staying most of | |
the time in specs, though there | |
only are rare | |
combinations of these three | |
factors where we aren't. But if | |
we are increasing the river | |
temperature, for example for 24 | |
degrees, then the areas where we | |
are off spec are...become much | |
more predominant. Also here it's | |
very hard to stay within this | |
specifications. So what we | |
learned from the model | |
is that we have problems to stay | |
in our specifications when the | |
river temperature is above 7 | |
degrees C. So then then the | |
the question was why is | |
that? And the engineers | |
often...suspected is that | |
this was because of the | |
cooling capacity of the | |
coolant. But before we went | |
into the real trial, we | |
compared our SEM model versus a | |
thermodynamic model based | |
on Chem CAD. | |
And what it pointed out was | |
that both models are | |
pointing in the same | |
direction, so there were no | |
no real discrepancies | |
between the both. | |
OK, this made us in an | |
optimistic mood and so we did | |
some real trials | |
and with the best | |
settings, and let's say, | |
approved the the predicted | |
things from the models. | |
And so it turned out, as I said | |
already, that what the engineer | |
suspected that the cooling | |
capacity of the cooler is not | |
sufficient. And so when you have | |
at higher river temperature, | |
then the heat transfer is too | |
small, and so the equipment... | |
equipment doesn't really run | |
anymore. So the next step now is | |
to use these data from from this | |
study here to justify another | |
investment which builds | |
a cooler here with a better | |
heat exchange capacity. | |
So thanks to Laura and Chris, we | |
could set up here the investment. | |
If you have questions so | |
please feel free to ask now. | |
Thank you. |
