Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
If you hover over the File Exchange option under "Community" and select "Add-ins", the next window that pops up has the "Upload Add-in" button. However, if you insead click on "File Exchange" and then from the next window that pops up, select "Add-ins" the window that pops up does not have the "Upload Add-in" button.
