Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Upload Addin button is missing
If you hover over the File Exchange option under "Community" and select "Add-ins", the next window that pops up has the "Upload Add-in" button.  However, if you insead click on "File Exchange" and then from the next window that pops up, select "Add-ins" the window that pops up does not have the "Upload Add-in" button.
IanAtJMP
Re: Upload Addin button is missing
This was fixed a while ago (sorry I can't give the exact date, and I'm sure you've noticed), but I wanted to make the answer official here as well.
Community Manager, Senior Digital Designer at JMP
Jeff_Perkinson
Thanks, Jim. We're working on it!
-Jeff
IanAtJMP
