  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Byron Wingerd's Blog
Byron_JMP
Simulation of Within and Between Variation for Specification Setting
Suppose you characterized the variation in the weight of tablets from a new process and then wanted to use that work to estimate the variation in weight that could be expected in a multi-tablet package.
One way to get the multi-tablet estimate is to simulate a large number of tablets with a specified mean and sigma, using a normal distribution. Then divide the individual tablets into a large number of subgroups, sum the weights and then look at the variation in the subgroupScreen Shot 2019-05-21 at 8.28.12 AM.png
Last Modified: Jun 2, 2019 12:57 AM
Comments
ParsaKarthik
Level III
Hi, kindly explain more on this. How do we do simulation using JMP?
ParsaKarthik
Level III
@Byron_JMP .. please help
Byron_JMP
@ParsaKarthik
The most basic simulations begin with a simple formula.   For example, Random Normal(10,1).  Which returns numbers from a normal distribution with a mean of 10 and a standard deviation of 1.
The next step is to determine how many draws to simulate, and that is just a matter of adding rows to the data table. (from the "rows" tab, pick add rows. )  Some number between 5,000 and 5,000,000 will probably work out well. (its just that 5 million is a little slower.)
JMP has a pretty good library of distribution functions to choose from.
In this article I explain how to use another tool in JMP to do the same thing using the profiler in some ways it is a little more complex, but in others it makes the simulation really easy to set up.
https://community.jmp.com/t5/Byron-Wingerd-s-Blog/Simulating-Multi-Step-Processes-and-the-Propagatio...
ParsaKarthik
Level III
@Byron_JMP .. Thank you!
