Effective data analytics is critical for the success of product development. Product development processes for adhesives and sealants involve data analytics for tasks needed at various project phases. Too many formulation chemists still depend on Excel for daily data recording, formulating, and analysis. While some chemists use JMP for statistical analysis and experimental design, JMP’s powerful and versatile data analytics should be used more universally for many daily tasks in product development. When shown how widely JMP can be used, more formulation chemists should see the benefits of adopting JMP as a daily tool.
This presentation shares examples of how easily JMP can be used in daily data analytics, in addition to the statistical analysis and DOE that most chemists use. A variety of examples are given, including handling data from literature and patent searches, analysis of raw materials, and a variety of formulation-related tasks such as formula stoichiometry calculation, mixing volume balance, data recording, and in tabulate/graph analysis. In addition, this presentation demonstrates how JMP is used for product selection, application trouble shooting, failure mode analysis, DOE, and more.
Hi , this is Stone Cheng ,
I 'm a technical director in Henkel Corporation .
I 've been using JMP for more than five years in product development .
Today I 'm happy to share
with our best practice in utilizing JMP data analytics
in product development of adhesive and sealants .
My presentation has two parts .
The part one is application gallery
where JMP used in various stage in product development will be discussed,
and in part two I will focus on using JMP
as a formulation worksheet with the demonstration .
In my organization ,
folks either have not heard of JMP
or have an impression that JMP is an advanced DOE software .
For the latter, it is true , but it 's not the whole truth .
Since there are other DOE software options ,
it is hard to persuade folks
to switch away from tool they are familiar with .
JMP is an excellent all- around data analytics tool .
To promote JMP adoption ,
we need example to demonstrate its power in the data analytics .
In my presentation ,
the example are taken from my experience in adhesive and sealants .
About Henkel .
Henkel is a 22- billion enterprise with two business unit :
adhesive technology
and consumer brand of laundry , home, and beauty care .
I 'm in the adhesive technology unit .
We are global adhesive leader serving 800 industries
with more than 20 ,000 products .
Let 's start with case number 1 .
One customer has a need ,
they may call a service center asking for product recommendation .
For example , a customer may need a room temperature adhesive hook
with the shear strength between 1 ,500 -3 ,000
and a work life between 15 -30 minutes
and in the package of 10 .
What we need is a searchable product selected guide ,
what is showing in our case 1 .
Once the product information are entered into the JMP table ,
one can use the tabulate and local data filter
to downselect the product
based on the customer requirement as shown in here .
This is a very, very powerful tool in the preformation stage .
My team has been applying this tool to search for formulation ,
pattern , literature and the raw material specifications .
In case number 2 ,
multivariate analysis is applied to a silver filler ,
which are used in making conductive adhesive .
From multivariable analysis ,
if we focus on the surface area ,
it has a moderate negative correlation with the tap density
and then it has a stronger positive correlation to lubricant amount
as measure at the weight loss at 530 AC .
There is a graphical way here and it 's a table format here .
With this analogy ,
chemistry can select the right silver package for the application .
Case 3 is the literature .
Literature is a great place for learning the chemistry and formulation
and this particular cited literature
illustrates how epoxy tensile strength
are affected by the mixture of two amine hardener .
The results are described qualitatively by a table
and a graph of the stress train curve here .
For formulator quantitative description is good ,
but learning via quantitative modeling
is even better for the prediction purpose .
In case number 3 ,
we take the literature data
and then create a two -factor column right here .
These are the epoxy /amine stoichiometry , or we call it the index .
The other factor is the fraction
of one of the amine PAE to the total amine fraction .
With the Fit Model platform, and we use the ISM model ,
it showed that the quadratic effect of the index,
together with two main effects, are all significant .
The prediction provider and the contour profiler
are used to quantify the learning and give the prediction .
In case number 4 ,
my group was assigned to support a technology platform
that include about 30 products .
Since we are not involved in the original formulation development ,
how to study the formulation family in this case is not trivial .
Looking at a big Excel table
with all the formulation certainly is not effective either .
Case number 4 is the example of addressing this challenge .
I select the three top most used ingredient
in these 29 formulation :
monomer 1 , 2, and then oligomer .
Then by using the hierarchical clustering analysis right here ,
right here our formula was identified to have very , very small distance
assumed right here ,
implying that they are in cross related .
Actually they are only different
in the photo initiator for different wavelength in this case .
We can add more ingredients one by one in this hierarchical clustering
and then learn the formulation family by using this method .
Most of the chemist analyze the formulation performance in Excel .
Case number 5 is a JMP tabulate that has the same data format as Excel .
Basically , various information of a formula
are displaced in the same column .
Like what you see here has a heading , has a recipe ,
has a processing material characteristic, and all the results .
To create such data structure ,
we need to enter data in JMP table in a special format
and that will be discussed in detail in part two of my presentation .
Case 6 is a silicone study involved 23 formulations
and more than 10 measurement property .
It is quite overwhelming trying to analyze the raw data in such big system .
We first construct a series of graph
with a property retention in Y and then the initial property in X .
For example , if you look at the first graph here ,
the adhesion retention is in Y and initial adhesions in X .
We also give the reference line , acceptance line for each axis .
When a formulation is selected , for example , I choose this point ,
they are in the quadrant with acceptable initial adhesion and retention ,
then all its associate property such as the tensile strength ,
elongation , hardness , all show up ,
also formulation all show up at the same time ,
these are all thanks to automatic highlight .
This is all thanks to JMP dynamic link capability .
Visualization analysis in such a way is very effective
for chemists to know the overall behavior of this system .
In polymer science ,
we measure the modulus of polymer as function of the temperature
with an instrument called dynamic mechanical analyzer , DMA .
DMA data has a temperature modulus
and then attend delta are typically transferred to Excel
in a wide format for plotting .
To overlay several DMA curve for comparison it is durable in Excel ,
but it 's not a trivial effort .
In case number 7 , we stack 74 DMA results together
and by using the graph builder ,
we can compare DMA results very , very quickly just by clicking .
I cannot imagine doing the same in Excel that has a 222 column .
It 's basically 74 sample times 3 signal per sample .
It 's going to be very difficult to handle in Excel environment .
A graph builder is excellent in turning
a very complicated graph seen in Excel into a visually digestible analysis .
In case number 8 , the needle pull strength
is illustrated in graph builder using four variable .
We have eight adhesive on the top ,
we have three different radiation system on the Y here ,
and we also have a four radiation time
and then two needle hub combination .
See how easy it is to understand this JMP graph
as compared to the Excel graph right here .
Good .
In case number 9 ,
we are conducting accelerated aging study for four epoxy prototype formulation
by measuring their initial adhesion
on three substrate and with a three replica .
The aging condition are two different temperature
and then eight week aging time with two weeks testing interval .
This aging design and the data was initially recorded in Excel
and we converted the Excel data into JMP table with seven column ,
seven column only
and the stack format and then we make a graph .
You will agree that the visualization in JMP graph builder in this case
is much easier to see the aging performance
than looking at the busy Excel table here .
In formulation stage , we frequently need to optimize composition .
Case number 10 is example
where two catalysts in polyurethane are optimized with the DOE design .
The factor are : catalyst ratio and the catalyst total amount .
There is a 10 -run face -center central composite design ,
the predictor provider indicating that the catalyst total amount factor
has a long linear effect on the work life .
The white area in the contour profiler
is actually the suite design space which desire work life .
In this case , 20 -28 .
It is important for chemistry to select
this green highlighted white area for better production robustness
than the area [inaudible 00:12:10] in blue ,
it has a higher tolerance for the amount change there
just in case operator makes some minor mistake .
That 's why it has a better production robustness .
We routinely see chemistry perform
statistics analysis of adhesion data like what you see here ,
but we hardly see anybody presenting
the results about the failure mode analysis .
In JMP the failure mode analysis can be performed in two places .
One is in the contingency analysis in Y by X platform
and the second one is using the graph builder .
The case number 11 is the example
applying to the silicone sealant
where the failure mode change before and after high temperature aging ,
before and after is clearly shown .
Clearly shown ,
Beside a good adhesion ,
adhesive rheology will need to be formulated
so that it can be effectively applied to the substrate .
We have a project to develop a seam sealant to protect the metal joint
by spraying process .
Case number 12 is the example that illustrating the complication
of spraying process with respect to the sealant viscosity variation .
We have three spraying variable .
They are the pressure , nozzle type , and then the head travel speed
and then we have one material factor in this case is the viscosity .
Initially , we plan the experiment in factorial DOE fashion ,
but one of the factor ,
the sparing pressure are very very hard to control .
We end up performing regression of the 40 round with ISM model
using the strain width and strain thickness as the response .
We get a good model with R -squared about 0 .91 for width
and 0 .81 for the thickness .
The modeling result tell us that the spraying condition
will need to be adjusted dependent on the sealant viscosity .
This is illustrated in this prediction profile here .
Each processing parameter
has their own machine limit and also desirable operation limit .
If this predicted processing variable are outside those limits ,
then the chemist will need to redesign
formulation reality and making sure that manufacturing
has the processing capability to meet the viscosity requirement .
This example show that the formulation design
and application constraint will need to be considered side by side
and JMP is actually a very good tool in facilitating this type of study .
Case number 13 is example that JMP
is used to handle huge instrumentation data sets .
In testing thermal interface material ,
the temperature at a different location and the power consumption data
are collected and then uploaded to the JMP .
Once the data are in JMP table ,
visualization of the data and data analysis of data set
as much as 500 ,000 row
are still very manageable and has a fast response .
That means the geometry actually can be used to handle instrumentation data .
We have a project to apply adhesive to software by the sensor printing
and this application is challenging with pinhole defect issue .
Process engineer changed six processing variable randomly
and then collect 21 wrong results .
His data analysis did not reveal any special trend ,
so the JMP was then used for the troubleshooting in this case
and the prediction partition analysis has identified factor F
as the key factor .
Later on we apply the predictor screening analysis
and then identify additional factor D that need a further investigation .
For JMP training , we learned that the predictor screening
can identify predictor , they may be weak alone ,
but strong when they are used in combination with other predictor .
In the scaling up and the manufacturing stage production ,
when the batch run into the issue ,
the raw material lot -to -lot analysis is one of the troubleshooting item
in order to isolate the potential raw material effect .
This exercise is typically done in the Excel table .
But when the multiple raw material
and multiple lots of each raw material are involved ,
it is difficult to look at a huge Excel table
to analyze the raw material effect .
In case number 15 , a polyester formulation
with three raw material
and about 45 separate lots are plotted verses the date of manufacturing
with the color scale of the gel time .
This heat map plot provide a visual analysis
for the production engineer to determine
whether a particular loss of raw material
is the major cause of the out of spec batch .
We turn the Excel table into a visual way for better analysis .
Statistics comparison in T -test or ANOVA analysis
are performed routinely in the product development .
A product benchmark exercise typically involves
multiple product running under various testing protocol ,
aiming to have a very comprehensive the product comparison learning here .
Case 16 is an example of statistic analysis
involved large combination of 23 products
and then more than 10 testing protocol .
In JMP , a large volume statistics analysis is not a challenge
since creating of the sub -table is not required in this case ,
as compared to other software .
One can utilize the column switchers
and the local data filter to create all the combination of property
and adhesive for statistics analysis .
Plus the results of each analysis
can be copied into a JMP journal to streamline the reporting .
For case number 17 ,
the needle bonding testing of light cured , historically , have a high data variance .
Case 17 use JMP to summarize 18 reports of needle -bound testing
which involve multiple lots of adhesive ,
and those are tested in various time .
The needle pore strand , its the COV , are plotted in graph builder
under various lighting , radiation condition ,
as well as the substrate combination .
With the local data filter here , one can easily
change the criteria selection to have a comprehensive comparison
of this adhesive and their consistency performance .
When this result was presented , everyone was amazed with the JMP capability .
It is so versatile and so powerful .
This is the last case for the application gallery .
In this case , number 18 ,
we use the parallel plot feature in the graph builder to demonstrate
visual comparison of 15 performance items and 10 adhesives .
Each performance has its own unit and scale
which provide a visual comparison more quantitatively in contrast
to the qualitatively comparison in spider chart which is used in Excel .
So far , in the 18 application gallery examples ,
the data are coming from literature , instrumentation ,
processing , and not much emphasis on formulated .
Now we will switch gear to discuss formulation creation ,
use worksheets , and it 's a JMP -based worksheet ,
not a traditional one using Excel .
Before we show you the JMP worksheet , let 's discuss about adhesive type .
Broadly speaking , adhesive can be divided in two categories :
one component adhesives or the two component adhesives ,
or 1K or 2K .
A 1K system like the Super Glue everybody knows
require no mixing and it can be cured
by moisture , by light , by heat , or by other method .
In case we are dealing with one component but heat cure adhesive such as epoxy ,
then we will need to design and then calculate the stoichiometry
or the index to balance the proportion of the epoxy to the amine hardener .
Then for the two component system , 2K system ,
their mixture will react at NDM temperature
so that they are kept apart before use .
In a 2K system , their stoichiometry will need to be designed and calculated
based upon the desired mixing ratio , either by weight or by volume .
There are some formulation calculation here we need to perform .
This type of calculation design historically been done in Excel .
This is the Excel .
Everybody know that Excel spreadsheet allow mixed data type in the same column
and its formulas can be applied to individual sales level
that make it very flexible as a formulation calculation worksheet .
Formula are typically organized in column format like this .
Each column has a full group of formulation information
such as their heading , which is the ID , their recipe ingredient ,
the formulation characteristic or processing parameter ,
and followed by the result .
What about the result ?
Excel -based worksheet is very useful .
Everybody using that because it 's easy to learn ,
but it does come with some shortcoming
such as first of all the row matching .
When you have a new ingredient or new testing results ,
you need to match to the right row , and they take time .
Then one may need to hide or unhide a column for comparison .
Then third thing is it 's harder to analyze the data
when the results are put in different tab .
It 's a tab -to -tab format .
It 's also very difficult to make a graph in such kind of a data structure .
JMP offer webinars to go beyond the Excel spreadsheet
in various features as listed here .
But the worksheet calculation is not emphasized .
Perhaps this is due to the inherent data structure that each column
cannot have a mixed data type
and the column formulas is applied to the entire column
which is not as versatile or flexible as compared to the Excel .
Despite of these constraints ,
we have developed JMP worksheet with the following objectives in mind .
It should have a broader capability
for formulation design , calculation , recording , and analysis .
It is all in one and we want to minimize cross -platform copy -pasting .
It should be easy to operate ,
easy data entry and use the JSL for a lot of the automation .
Then the final data set is ready for machine learning exercise .
Let 's look at our Gen1 , and that is for one component system .
This includes four data group .
We have a formulation ID , we have a recipe ,
we also have a material processing characteristic ,
and then we have a testing result right there .
The four data group are the same as what you see in the earlier Excel worksheet ,
but layer structure was organized in the column from the left to right .
This is different from the Excel which is from top to the bottom .
The data of the three group , 2 , 3 , and 4
are shared and recorded in the same column ,
which has a numeric data type .
All the recipe , all the testing results , and all the formulation characteristics
all in the numerical data type ,
and they are documented in the same column here .
With this kind of a format
The data was also stacked together .
I have formulation 1 here , formulation 2 here .
With a stacking format , one can freely enter the new ingredient
or new testing item without needed to match the role as needed in Excel .
JSL was also created to enable data analysis
in either tabular way or in a graph format .
This is in a tabular way .
Chemist can pick several formulation ID and compare their recipe characteristic
and performance in a very , very condensed format here .
This is very different from Excel without needing to hide /unhide columns
to bring formulation to be adjacent to each other .
Much , much easier under the JMP format here .
Besides tabulation , one can make a graph
of the property versus the property comments or the sample ID ,
but not the ingredient percentage .
This graph can be combined with the recipe table here
into a group under the dashboard operation .
This make it as a very effective visualization analysis .
As for testing involves multiple replicates .
We typically just record the average result .
But one can enter the individual replicate data in the property column ,
and then perform the T test , the all -over test , using this worksheet here .
In case people doesn 't want to enter data in this way ,
there is the other way to virtually link the data file with the replication result
with the worksheet .
That will be shown later in the presentation .
So far , what you see is our Gen1 worksheet
which involves no formulation calculation .
Chemists in my group has been using this tool for more than one year .
They get used it its easy data entry and very , very powerful tabulation analysis .
Next we 're going to look at the Gen 2 worksheet
that can overtake the Gen1 feature .
It has an additional feature
for the formulation calculation for the 1k and 2k system .
This worksheet also link with the other JMP file
that has additional raw material information needed for calculation .
We have the other worksheets , we call Gen 3 , that are designed
to deal with the solvent borne system .
It also allow formulator to incorporate master batches ,
but due to the time constraint it will not be discussed here .
This is our Gen2 worksheet .
There are three sections .
We have a heading and then the formulation input section right here .
The middle one , we have a calculation output .
The third section is the processing material characteristic
and also the testing results .
Section 1 and section 3 are like the one in Gen1 ,
but the section 2 here is newly added .
The column row name is used to link the reference file
that has additional data information needed for calculation .
You can see the symbol for the virtual link right here .
After chemist enter the formulation ID ,
they will specify for columns , parts , row , name , and initial weight .
If they are doing the 2K system , they need to also specify the mixing ratio
either by index , by volume , or by weight ratio .
Then the worksheet will output the mixing ratio characteristic here
again by index , by volume , or by weight .
They also provide a normalized composition , either by part .
By part means A and B sum up together by themselves and equal to 100 ,
or A and B mixed together .
We call it normalized by total here .
After seeing this one and the chemist can perform the experiment
and then come back to enter the results right here .
The other thing is
in the property material characteristic , we have the other column called Lookup .
This can extract the information from the calculation
and also the raw material fraction percentage ratio
and automatically displays right here .
Then chemists just need to copy parameter in the value enter column
and then this will be automatically
transferred to the two normalized percentage column for display purpose .
We also have three JSL there to facilitate in analysis .
The first one is showing you normalization , normalized by total .
That means A and B being mixed together and sum up to 100 .
Here , I showed you the formula ,
showed you the characteristic and showed you the result .
You have a second JSL that 's normalized by part .
In this case , you can see your part A formulation and part B formulation ,
and then A and B all have been normalized to 100 by themselves .
With the other JSL , we can change the formulation
worksheet format from the stacked to the white format .
In this case their ID performance , individual ingredient ,
and then the characteristic will all have their own individual columns .
With this format , one can make the graph
with the property versus the ingredient percentage
which cannot be done under the stack format .
One can also looking for the correlation
between the performance or the performance with the formulation characteristic .
At this moment , I like to show you the live demonstration .
This is the formulation worksheet I just showed you in the PowerPoint .
Basically , we have the heading .
Then we have a formulation input section .
We have a calculation between n1 and n2 .
Anything here is for calculation .
Then we have the last section here ,
that is a performance and then the property material characteristic .
I mentioned that we have a JSL ,
allow people to look at this result easily .
Let 's look at this one , JSL by total .
We can easily highlight any formulation or compare 2 and 8 ,
and then compare their formulation and their result .
These are mixed together .
We can look at it by part .
Part A here and then part B here .
They all sum up to a hundred by themselves .
Easily , we can compare
Oh no , I need to remove this one first .
I can compare formulation easily by manipulating the local data filter .
Again with the JSL , we click the Join All .
We are turning the stack format into a wider format .
Each row belong to one formulation with the heading here ,
with their property , with their formulation ,
and with their formulation characteristics showing right here .
For machine learning ,
we can highlight a role ingredient and then just
manually add zero so that each ingredient has zero or whatever ,
and then now we can do this one .
We can create a summation or something , easy to operate in this .
I 'm going to show you next how this one work in the sense that
assuming that we 're going to create a formulation .
I 'm going to copy the heading .
Sorry , I 'm going to delete everything here because I create this one already before .
I 'm going to delete the demonstration one .
I 'm going to create it from scratch
by copying the heading here .
I change the name to Demonstration here .
I will copy the formulation because
I 'm going to modify formulation from this one , the DOE 8 .
Then the DOE 8 is based on one -to -one mixing ratio by volume .
But in this new one , we could change it to one -to -two mixing .
A divided by B is one divided by two , so it will be 0 .5 .
Then I copy the heading including the mixing ratio all the way down .
Now all the calculation has been done here .
With this weight percentage I 'm entering , it showed that the material has an index
model ratio A to B to be 0 .65 , which is too low .
We need to , using our chemistry knowledge , to turn this around .
In this case , for example , I make this one 2 .
I can easily make this one into 1 .05 .
That is the range I 'm looking for .
Basically , assuming it is the design that we want , formulation we want ,
the next thing we want to do is to copy
some of the testing that we already had before ,
that we are monitoring before ,
but without the results , of course .
We have a new result here , so I 'm going to delete that one .
But we also want to add additional property
which for example is viscosity
measure at a room temperature .
With this section here , then we want to extend our heading
to specify those are belong to this formulation .
As soon as I specify the heading ,
the Lookup automatically give me
the information such as the missing characteristic .
1 .5 or 0 .5 , they are automatically copied to here through the Lookup function
and then the feeder loading in the formulation normalized to Total
while also being extracted , sum up together and put it right here .
Now I can copy this information , put them in value enter ,
and specify my mixer is number 2 ,
and then start to enter my results , time that 's going to be 80 ,
and adhesion 450 assuming , viscosity 20 ,000 .
I 'm pretty much finished everything , so let 's look at the result here .
We just enter Demonstration .
This one was based on the DOE number five .
DOE number five is one to one mixing and this Demo is only one to two mixing ,
and we added the viscosity result right here .
It 's very , very easy .
One click you see the result
and in the format it 's very easy to understand for comparison .
This is the end of my demonstration .
Let me go back to the presentation here .
We consider the JMP worksheet that I 'm just showing you is an integrated platform
and here is the summary .
The worksheet in the stack format , here ,
is used for formulation design , calculation and for recording the results .
The data entry of raw material
which is needed for the worksheet is minimized by virtually linked with
the other file that has additional raw material information .
JSL was widely used to automate
the worksheet output to the tabulate , to graphic , to the statistic analysis ,
and also to create a table with wide data format .
The wide data format , they already have a data structure
for modeling via the machine learning
and also allow the graphical analysis using the ingredient as one of the axis .
Then since each of the row in this wide format
is a unique tool formulation ID ,
this actually can be used as a reference table
to join the other JMP file that has a testing result that has a replication .
When these are joined together ,
then we can plot the raw data and do statistic analysis ,
either as function of the ingredient or as function of the formulation ID .
This JMP Integrated Worksheet Platform
truly illustrates it is an all -in -one platform , very , very capable .
In summary , JMP is not just an advanced DOE software .
JMP 's data analytics has been effectively utilized
in my group for product development
at various stage to speed up the innovation process .
JMP -based formulation worksheet is an integrated platform that feature
broad formulation capability , all in one , easy operation ,
and machine learning ready data structure ,
and more and more waiting to be further explored .
With this , thanks for your attention
and I also like to acknowledge the people I work with and learning to JMP together
and also our management system for supporting JMP adoption initiative .
Thank you very much .
Published on ‎03-25-2024 04:54 PM by | Updated on ‎07-07-2025 12:11 PM
About Henkel .
adhesive technology
In case number 2 ,
With this analogy ,
In case number 3 ,
In case number 4 ,
Good .
In case number 9 ,
seven column only
Clearly shown ,
as the key factor .
or 1K or 2K .
This is the Excel .
The other thing is
