JMP 17 introduces the Easy DOE platform, providing both flexible and guided modes to users, aiding their design choices. In addition, Easy DOE allows for the DOE workflow from design through data collection and modeling. This presentation offers a preview of the new Easy DOE platform, including insights from a 7-year-old using the new platform on a DOE problem of her choosing.
Hello . I'm Ryan Lekivetz , Manager of the DOE and Reliability team at JMP .
And I'm all Rory Lekivetz.
We're here today to talk to you about Easy DOE . The question is it easy enough for a seven- year- old? N ow that you're eight years older you're a lot wiser to answer that question.
For those of you who don't know about Easy DOE, so it's a new platform and JMP 17 . Now , the idea with Easy DOE is it's going to be a new file type that encompasses the design through the analysis of a designed experiment . No more do you need to worry about splitting up , going from the DOE platform to a data table and then running the analysis separately .
Now , the idea with Easy DOE is that we're trying to aid novice users through that entire workflow . There's going to be a guided mode where we've tried to add hints and useful defaults to guide those users while at the same time having a flexible mode for those who are more comfortable with Easy DOE .
Now before we started doing this idea with Easy DOE and running our experiment, I did talk to Rory about the daily workflow . I f you open up the DOE documentation , we outline this idea of a Easy DOE workflow which goes through the described phase , which is where we identify the goal and the responses and the different factors, specify where we're looking at our model . We create the design , collect the data , fit a model to that data , and then use that model to predict .
Right now , if you think about the way traditionally we've done this in JMP, at that design phase is where we create the data table . Using that data table the experimental go and collect the data and then perform the remaining steps ending it. N ow what you'll see in Easy DOE , there's the tabbed interface where each tab represents one of these steps in the DOE workflow .
Now what was the experiment that we did ?
Paper airplanes .
Rory had found a website that talked about different ways to create paper airplanes . You want to tell them what was the response ? What were you trying to measure ?
We were trying to measure the distance which was inches .
What factors did you end up deciding that we could change ?
For factors we decided on war plane type, paper type, flying force and paperclip .
Yeah . Now you to tell them about some of these different tabs . Okay , so let's start . What was the define tab ?
The define tab was where you got to choose your factors and your responses .
That's right . I should mention here as well that when we were using Easy DOE , I left Lory in control of the entire platform . She launched it . She was the one entering everything and clicking between tabs and all of that . I think after the define tab , we moved to the next. What was that next tab?
Model. F or the model tab , you had to choose w hich one of these four was the best for your experiment.
Now I'll say too, on this one this is where we had to talk a little bit more about what these different model types mean . Of course , for a seven- year- old and even an eight- year- old , now that idea of understanding interactions can be a difficult thing .
Now , the main effect versus the interaction . One of the nice things was the website that we had found about creating paper airplanes . It talked about how some of the different types of paper airplanes do better when you throw it hard versus light .
It already had discussed that idea of interactions, so that's why ultimately, I helped her decide on picking that two- factor interaction model with the main effects .
Once we had that model, then what happened?
Then was the design . The design shows you what you're going to be making . Since we were doing paper airplanes and we entered the factors for tight paper throwing for some paper clip , then it sounds like different types , different papers, different throwing forces like route and paper clip or no paper clip.
Yes , I think we made the 16 different paper airplanes and so each one was a different one . I think we put a number on it . Is that right ? We label it with a number one . Yeah . Then what happens after we have that design, what do we do with that ?
Then we do good data entry . With data entry is where you enter in how many inches you want.
Yeah . I think we went outside and we took those paper airplanes and we flew them anyway and then just measured that . Yeah , that's right . W hat happened after we had that data entry ?
Then we go to be analyzed . Analyze is where you figure out which ones were the best.
Yeah , which ones really were impacting that distance flown . Now , I should mention here , so this is a novel thing in Easy DOE . The confidence intervals for each of our different effects are clickable .
All right, I had actually thought that this was going to be a really difficult time to talk about the analyzed . But as soon as we got there, so it starts with all of the terms in the model and very quickly figured out that you could click on them . She looked at the ones that were close to zero and just removed them .
On the top was actually her model . She actually picked a much simpler model than even what the best model . You'll notice there is a best model one . But one could argue that I actually might even prefer her model to the one that was picked by the best model .
But again , still a very nice way to play around with your model and see what happens if term enter o r are removed just by clicking on those confidence intervals . T hen after we moved to the analysis , what was that tab they had?
The predict tab was where you could see which types or which t hings were the best . The best look like it would probably be a dirt metal construction and differently for us since it was like, the hard in blue light was like…
Did it matter or not really?
Not really . It would be like you could do hard or light in your paper .
I should mention here, so it was interesting to see she hadn't really seen the prediction profiler so much before . I mean , wasn't familiar with it . S he did have to be told to click in there to see what happens . But even for a seven- year- old , it's interesting to see once they have that sense that they can click within that prediction profiler , she was really able to get the hang of it .
J ust some final thoughts from Easy DOE . I asked Rory a few questions ahead of time . What would you like to tell people about Easy DOE ?
It was really fun .
Yeah . If you were to do this experiment again , would you change or what would you change ?
The factors , maybe different days for the weather .
You think like it might be windy on some days and not on others . F or my own perspective , you know , so she was actually able to complete this with minimal help from me . I mean , she was in control the entire time of the Easy DOE platform . A lot of these different choices she was making on her own . Even when it came to the factors that she picked .
As well she actually did help us find some usability issues . There were pieces like in the design tab that I think we improve throughout because of users trying this out not just for her , but as well as other users that we had in the DOE program . The model she definitely needed help with , but the analysis was easier than expected .
Just some references , acknowledgments . Really , I just want to thank all the members of JMP that helped in the development of Easy DOE . There's a huge list that you'll actually see . We have a Discovery America presentation there as well , where we talk about this in a little bit more detail . Again , all the feedback from external and internal users that have seen this before the release of 17 and since it's been released .
Thank you for your time and joining us today . We hope you'll join us during Discovery where we can discuss this poster . Not sure yet if you'll be able to join us , but I definitely will be and hopefully you as well . Thank you .
Thank you .
0 Comments
Published on ‎03-25-2024 01:28 PM by Staff | Updated on ‎07-07-2025 12:13 PM
Paper airplanes .
It was really fun .
Thank you .
