Welcome to the JMP User Community!
Ask questions, get answers, meet other JMP users
Learning Resources
Latest Discussions
  • Replicated runs for accounting the variance
    Hi ,        I had a custom design with 6 runs for having a model  to predict the effect of temp and speed on performance . I had 5 samples each from each run. But...
    Mathej01
    Discussions |
    May 6, 2024 8:15 AM
    89 views | 1 replies
  • Begin Data Update
    Hello I have a table and would like the empty volume to be updated to 0 I have written the script to update the column "19-04-2024" the problem is the name of the column can be changed and I p...
    Dennisbur
    Discussions |
    May 6, 2024 7:31 AM
    58 views | 3 replies
  • Jmp Update & Python
    Up to now, my Python distribution was separate from Jmp. So, after an Update of JMP the Python installation was still the same - with all packages.   With JMP18 I understood that Python comes...
    hogi
    Discussions |
    May 6, 2024 6:37 AM
    56 views | 1 replies
  • Interaction Profiler: show Datapoints?
    In Jmp18, there is a new feature to activate data points in Prediction Profiler enhancements in JMP® 18  Is there an option to activate the data points as well for interaction profiler? ...
    hogi
    Discussions |
    May 6, 2024 6:30 AM
    33 views | 0 replies
  • Verify and use existing Definitive Screen design with JMP?
    Hello, I obtained a Definitive Screen design for a DOE Experiment by ChatGPT 4.0. It looks reasonable (after several discussions). Can JMP verify if the Definitive Screen Design is acceptable? if I...
    Thommy7571
    Discussions |
    May 6, 2024 5:18 AM
    200 views | 8 replies
view all discussions
