sisherman
Risk ratio vs hazard ratio
The proportional hazards model in JMP reports the ratio as a "risk ratio". How is this different from a "hazard ratio" and why does JMP report the risk ratio instead of the hazard ratio?
jiancao
Re: Risk ratio vs hazard ratio
The risk ratio calculated by JMP’s Fit Proportional Hazards is the ratio of hazard rates. It measures the relative risks. You can refer to risk ratio as hazard ratio.
jiancao
