The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
View Original Published Thread
How to use Korea Map Shape
The concept of Map Shape is the task of drawing the frame of a map, unlike maps provided on the Internet. JMP provides instructions on how to use these features so that users can easily utilize them (refer to the link below for details).
Create Maps
Basically, the Map Shape provided in JMP was as follows.
If you look on the right, Canada / Italian / German / Japan / China / UK / US, etc. are provided, but unfortunately Korea was not on the list.
undefined
The attached KOR-NAME.jmp and KOR-XY.jmp files support that function.
Please copy the two files to the path below. Administrator permission may be required when copying.
C:\Program Files\SAS\ JMPPRO\14 \Maps
The blue part of the path above may vary depending on the user's JMP product and version.
ex) For users using JMP 13 Version, C:\Program Files\SAS\ JMP\13 \Maps
If you copied two files while running JMP, After JMP ends Please run it again.
In general, by dragging the 50 states of the United States onto a Map Shape, you could automatically obtain the following topographic map of the United States.
undefined
To obtain a topographic map of Korea, you can easily draw a topographic map of Korea using the data below (please pay attention to the variable name Region).
undefined
Now you can easily draw a topographic map of Korea as shown below. The variable name does not matter (Region / Region / City, etc.). However, you only need to type correctly the abbreviated areas such as Seoul/Busan/Gwangju (17 regions). Then drag Region to Map Shape. end!
undefined
As above, the analysis using the topographic map of the Korean Peninsula was shared through JMP Public. Please refer to the link below.
undefined
inquiry : DaeYun.Kim@jmp.com
This post originally written in Korean and has been translated for your convenience. When you reply, it will also be translated back to Korean.
Comments
DaeYun_Kim
2021년 3월 새롭게 출시된 JMP 16부터는 한국(정확하게는 남한)의 Map Shape이 기본으로 제공됩니다.
