The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
View Original Published Thread
Craige_Hales
Disk Drive TB/$
Time to upgrade the 8TB drive on a video server. One of the choices sticks out.
Scanning the TB/Dollar column also locates the outlier.Scanning the TB/Dollar column also locates the outlier.
This is an old model USB desktop drive that I'm not recommending one way or the other; my existing drive is the 8TB model and I like it because it spins down when not in use. I don't like it because it takes 15 seconds to spin back up.
Comments
jthi
I was building desktop PC in 2011 (I think) when the floods hit Thailand? and affected HDD supply and the prices did increase quite heavily. I needed large HDD to save my files and tried to stay on the budget. Luckily I did notice that the prices of USB hard-drives didn't increase in all shops so I did buy one of those, removed the casing and got myself HDD.
At some point I started noticing some small hiccups from time to time... it was caused by the spin-down (and especially spinning up) after drive was not being used. This caused some issues when gaming and so on, so I wrote python script which did write some small file to the drive from time to time to avoid the spin down. Worked great back then!
