Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
@lwx228 asked How do add text to a cell that has an image loaded? This idea is pretty simple: put the picture in a frame box, use a graphic script to decorate, take a new picture. The details to get a nice round-trip image are a bit more complicated. The frame needs to be sized and scaled, and the picture positioned, and the final image cropped.
// open the original
original = New Image(
"https://upload.wikimedia.org/wikipedia/commons/thumb/f/fc/Oroblanco_%28sweetie%29_fruits.jpg/320px-Oroblanco_%28sweetie%29_fruits.jpg"
{xSize, ySize} = original << size;
// use a frame to do the drawing, make the original fit the frame exactly
gb = Graph Box(
<<backgroundcolor( "orange" ), // to see errors better
FrameSize( xSize + 1, ySize + 1 ), // the +1 is required, 4 times
X Scale( 0, xSize + 1 ),
Y Scale( 0, ySize + 1 ),
// apparently x and y are different. this is correct in 17EA.
<<Add Image( image( original ), bounds( top( 0 ), Left( 1 ), bottom( ySize ), Right( xSize + 1 ) ) ),
// draw something on top of the image
Text( Center Justified, {xSize / 2, 10}, "https://en.wikipedia.org/wiki/Oroblanco" );
Pen Color( "blue" );
Pen Size( 3 );
Circle( {1 * xsize / 4, ysize / 2}, 10, 20, 30, 40, 50 );
Circle( {3 * xsize / 4, ysize / 2}, 10, 20, 30, 40, 50 );
// capture an updated image
updated = gb[framebox( 1 )] << getpicture;
// crop added border. "updated" is the final image.
updated << crop( Left( 1 ), top( 1 ), Right( xSize + 1 ), bottom( ySize + 1 ) );
// the remainder is just to verify the image...
originalMatrix = original << getpixels;
newMatrix = updated << getpixels;
diff = (originalMatrix - newMatrix != 0);
New Window( "bitmaps",
V List Box(
gb,
Spacer Box( size( 1, 10 ) ),
Button Box( "picture credit: Ivar Leidus, Creative Commons Attribution-Share Alike 4.0 International",
Web( "https://en.wikipedia.org/wiki/File:Oroblanco_(sweetie)_fruits.jpg" ),
<<underlinestyle
H List Box(
Spacer Box( size( 2, 2 ) ),
V List Box( Text Box( "original" ), original ),
V List Box( Text Box( "updated" ), updated ),
V List Box( Text Box( "diff" ), New Image( diff ) ),
The results, below, shows the image filling the frame box with the decorations, and three images below. The left image is the original, the center is modified, and the right is the difference. The difference is mostly black, no change, which is good. The text in the difference is fuzzy because the anti-aliasing made subtle changes at the edge of the text.
