Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Using JMP® Pro for Enhanced Marketing Analytics and Consumer Research
Published on ‎11-07-2024 03:28 PM by Community Manager Community Manager | Updated on ‎04-08-2025 09:13 AM
See how to:
  • Process, visualize, prepare to analysis and interpret results for free-form text
  • Launch Text Explorer
    • Identify Terms as the smallest pieces of text, similar to words in a sentence; Phrases as short collections of terms; and Documents as collections of words in a table cell
    • Use Stemming to combine words that have common roots
    • Use Regular Expressions to find patterns in words
    • Evaluate and visualize prevalence or Terms and Tokens (number of words)
  • Interactively examine and use Word Cloud to visualize text and interactively see full text (Documents) related to specific Terms
  • Add new variables that summarize responses, for example, opinions collected in a survey
  • Use JMP Pro Latent Class Analysis to group top Terms into clusters and Discriminant Analysis to show the relationship of Terms to a response
  • Understand how JMP uses Latent Semantic Analysis and a partial Singular Value Decomposition (SVD) to reduce Terms into a manageable number of dimensions for analysis
  • Examine the Document Term Matrix (DTM)
    • See how DTM changes Terms to numeric values that can be used in analysis
    • Clean up DTM to remove empty cells
  • Cluster and weight similar Terms and Phrases
  • Group related Terms into latent groups (Topics) and examine the Terms most and least likely to be associated with each Topic
    • Use Topic information to build predictive models
  • Understand and run Association Analysis (Affinity Analysis, Market Basket Analysis, Pattern Recognition)
    • Understand and specify Support, Confidence and Lift values to identify Association Rules (relationships of Terms)
    • Examine and interpret Confidence and Consequence for each identified association
Note: Q&A included at times 29:36 , 31:07 and 31:23 .
Resources
Start:
Thu, Jul 9, 2020 02:00 PM EDT
End:
Thu, Jul 9, 2020 03:00 PM EDT
Labels (1)
0 Comments
