Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Unlocking the Power of Graph Builder
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
See how to:
  • Build Waterfall Plots (clinical trial subject tumor volume example)
    • Order information ascending and descending
    • Modify axis setting for scale, label, ticks and reference lines
    • Add and modify bar (row) colors
    • Select and deselect variables
    • Specify Value Order·
    • Use gallery palette to change graph type
    • Use jitter to help see overlapping points·
    • Label/unlabel particular points in graph
    • Add boxplots for continuous variables·
    • Use and interpret violin contour plots
    • Modify fill color and patterns
    • Nest categorical variables
    • Swap Axes
    • Use Overlay Zone to  overlay two graphs in same space
  • Build Line Graphs (US housing data)
    • Use Group X, Group Y, Wrap and Page zones
    • Cluster information
    • Create trellis display of line graphs and then save information from the graph into a data table that displays graphs
    • Use Wrap zone to display clusters in sections of one graph window
    • Use Page zone to display clusters on separate graphs
    • Highlight selective data using Legend
Resources
Start:
Tue, Oct 6, 2020 02:00 PM EDT
End:
Tue, Oct 6, 2020 03:00 PM EDT
0 Comments
