Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
%3CLINGO-SUB%20id%3D%22lingo-sub-809980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDie%20volle%20Leistungsf%C3%A4higkeit%20von%20Graph%20Builder%20nutzen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CIFRAME%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F1872491364001%2Fdefault_default%2Findex.html%3FvideoId%3D6090071961001%22%20width%3D%22300%22%20height%3D%22150%22%20allowfullscreen%3D%22%22%20webkitallowfullscreen%3D%22webkitallowfullscreen%22%20class%3D%22video%20floatRight%22%20mozallowfullscreen%3D%22mozallowfullscreen%22%3E%3C%2FIFRAME%3E%3C%2FP%3E%0A%3CP%3EErfahren%20Sie%2C%20wie%20Sie%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EErstellen%20Sie%20Wasserfalldiagramme%20(Beispiel%20f%C3%BCr%20das%20Tumorvolumen%20bei%20klinischen%20Studien)%3CUL%3E%3CLI%3E%20Informationen%20aufsteigend%20und%20absteigend%20sortieren%3C%2FLI%3E%3CLI%3E%20Achseneinstellungen%20f%C3%BCr%20Skala%2C%20Beschriftung%2C%20Teilstriche%20und%20Referenzlinien%20%C3%A4ndern%3C%2FLI%3E%3CLI%3E%20Hinzuf%C3%BCgen%20und%20%C3%84ndern%20von%20Balken-%20(Zeilen-)Farben%3C%2FLI%3E%3CLI%3E%20Ausw%C3%A4hlen%20und%20Aufheben%20der%20Auswahl%20von%20Variablen%3C%2FLI%3E%3CLI%3E%20Wertereihenfolge%20festlegen%C2%B7%3C%2FLI%3E%3CLI%3E%20Verwenden%20Sie%20die%20Galeriepalette%2C%20um%20den%20Diagrammtyp%20zu%20%C3%A4ndern%3C%2FLI%3E%3CLI%3E%20Verwenden%20Sie%20Jitter%2C%20um%20%C3%BCberlappende%20Punkte%20besser%20zu%20erkennen%C2%B7%3C%2FLI%3E%3CLI%3E%20Bestimmte%20Punkte%20im%20Diagramm%20beschriften%2FBeschriftung%20aufheben%3C%2FLI%3E%3CLI%3E%20Boxplots%20f%C3%BCr%20kontinuierliche%20Variablen%20hinzuf%C3%BCgen%C2%B7%3C%2FLI%3E%3CLI%3E%20Verwenden%20und%20Interpretieren%20von%20Violinkonturdiagrammen%3C%2FLI%3E%3CLI%3E%20F%C3%BCllfarbe%20und%20Muster%20%C3%A4ndern%3C%2FLI%3E%3CLI%3E%20Verschachteln%20kategorialer%20Variablen%3C%2FLI%3E%3CLI%3E%20Achsen%20vertauschen%3C%2FLI%3E%3CLI%3E%20Verwenden%20Sie%20die%20Overlay-Zone%2C%20um%20zwei%20Diagramme%20im%20selben%20Bereich%20zu%20%C3%BCberlagern.%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CUL%3E%0A%3CLI%3EBuild%20Line%20Graphs%20(US-Wohnungsdaten)%3CUL%3E%3CLI%3E%20Verwenden%20Sie%20die%20Zonen%20%E2%80%9EGruppe%20X%E2%80%9C%2C%20%E2%80%9EGruppe%20Y%E2%80%9C%2C%20%E2%80%9EUmbruch%E2%80%9C%20und%20%E2%80%9ESeite%E2%80%9C.%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%20Cluster-Informationen%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%20Erstellen%20Sie%20eine%20Gitterdarstellung%20von%20Liniendiagrammen%20und%20speichern%20Sie%20dann%20Informationen%20aus%20dem%20Diagramm%20in%20einer%20Datentabelle%2C%20die%20Diagramme%20anzeigt%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%20Verwenden%20Sie%20die%20Wrap-Zone%2C%20um%20Cluster%20in%20Abschnitten%20eines%20Diagrammfensters%20anzuzeigen%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%20Verwenden%20Sie%20die%20Seitenzone%2C%20um%20Cluster%20in%20separaten%20Diagrammen%20anzuzeigen%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%20Markieren%20Sie%20ausgew%C3%A4hlte%20Daten%20mithilfe%20der%20Legende%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH4%20id%3D%22toc-hId-1423606062%22%20id%3D%22toc-hId-1424314136%22%3ERessourcen%3C%2FH4%3E%0A%3CUL%3E%0A%3CLI%3EPharmaSug-Artikel%20%C3%BCber%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.pharmasug.org%2Fproceedings%2F2012%2FDG%2FPharmaSUG-2012-DG13.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EWasserfall-Grundst%C3%BCcke%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3EFreddie%20Mac%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freddiemac.com%2Fresearch%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EDaten%20zum%20Wohnungspreisindex%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3EDokumentation%20zu%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Faemauthor.unx.sas.com%2Fcontent%2Fjmpbp%2Fen%2Fredirects%2Fsupport%2Fgraph-builder-options.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3EAnpassen%20von%20Graphen%20an%20Fenster%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3EVideos%20auf%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Faemauthor.unx.sas.com%2Fcontent%2Fjmpbp%2Fen%2Fevents%2Fondemand%2Fmastering-jmp%2Fusing-geographic-maps.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3EVerwenden%20geografischer%20Karten%20mit%20Graph%20Builder%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3EBlog%20%C3%BCber%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fblogs.sas.com%2Fcontent%2Fjmp%2F2015%2F03%2F05%2Fgraph-makeover-measles-heat-map%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3Egrafische%20Darstellung%20der%20Masernh%C3%A4ufigkeit%3C%2FA%3E%3CSPAN%3E%20%3C%2FSPAN%3Enach%20Staat%20und%20Jahr.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EDatenexploration%20und%20-visualisierung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Unlocking the Power of Graph Builder
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:39 PM
See how to:
  • Build Waterfall Plots (clinical trial subject tumor volume example)
    • Order information ascending and descending
    • Modify axis setting for scale, label, ticks and reference lines
    • Add and modify bar (row) colors
    • Select and deselect variables
    • Specify Value Order·
    • Use gallery palette to change graph type
    • Use jitter to help see overlapping points·
    • Label/unlabel particular points in graph
    • Add boxplots for continuous variables·
    • Use and interpret violin contour plots
    • Modify fill color and patterns
    • Nest categorical variables
    • Swap Axes
    • Use Overlay Zone to  overlay two graphs in same space
  • Build Line Graphs (US housing data)
    • Use Group X, Group Y, Wrap and Page zones
    • Cluster information
    • Create trellis display of line graphs and then save information from the graph into a data table that displays graphs
    • Use Wrap zone to display clusters in sections of one graph window
    • Use Page zone to display clusters on separate graphs
    • Highlight selective data using Legend
Resources
Start:
Tue, Oct 6, 2020 02:00 PM EDT
End:
Tue, Oct 6, 2020 03:00 PM EDT
0 Comments
