Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Tracking and Trending Manufacturing Metrics
Published on ‎11-07-2024 03:30 PM by Community Manager Community Manager | Updated on ‎04-08-2025 09:12 AM
See how to:
  • Understand how control charts to identify special causes of variation.
  • Build charts using Control Chart Builder
  • Save Control Charts to PowerPoint
See how to:
  • Build IR Charts
  • Avoid issues related to missing values
  • Limit data points to improve readability
  • Automate reproducing your work using scripts created by JMP and by implementing techniques to make the x-axis scaling dynamic
See how to:
  • Use two different approaches for handling control limits
    • Use and reuse the same fixed limits based on best case when the process was in control
    • Calculate limits each time you have new data
  • Save control limits both to the column and to a new table
  • Add control limits from a limits table to a table containing the variables for the control charts
See how to:
  • Use JMP Profilers to find settings that will result in the lowest probability of defects
  • Model the process and compare maximized process settings to those for minimized defects
Resources
Start:
Fri, Oct 9, 2020 02:00 PM EDT
End:
Fri, Oct 9, 2020 03:00 PM EDT
0 Comments
