Scott Wise's Blog
scwise
Master List – Pictures from the Gallery – Advanced Graph Building Series
Scott Wise – Principal Systems and Statistical Engineer
Updated: 11/07/25
Links, Snapshots, and Graphs Featured
  • Custom Interval Area
  • Ordered Bars with Color
  • Flow Chart
  • Broken Time Axis
  • Reference Range & Text
  • Marginal Chart
Pictures from the Gallery 2 (2017): https://community.jmp.com/t5/Discovery-Summit-2017/Pictures-From-the-Gallery-Two-Select-Advanced-Gra...
  • Funnel Plot
  • Waterfall Chart
  • Curved Line Chart
  • Table Squares
  • Density Overlays
  • Sankey Diagram
Pictures from the Gallery 3 (2018): https://community.jmp.com/t5/Discovery-Summit-2018/Pictures-From-the-Gallery-3-Select-Advanced-Graph...
  • Two-Way Error Bars
  • Likert Scale Bars
  • Multi-Variate Bullet
  • Trellised Heat Maps
  • Packed Bar Pareto
  • Volcano Plot
Pictures from the Gallery 4 (2019): https://community.jmp.com/t5/Discovery-Summit-Tucson-2019/Pictures-From-the-Gallery-4-Select-Advance...
  • Positive Grid Plot
  • Graphs in Map
  • Variable Width Bar Chart
  • Advanced Pareto Plot
  • Butterfly Chart
  • Gantt Chart
  • Clipped Contour Map
Pictures from the Gallery 5 (2020): https://community.jmp.com/t5/Discovery-Summit-Americas-2020/Pictures-from-the-Gallery-5-Select-Advan...
  • Informative Box Plots
  • Ridgeplot Densities
  • Area Range Plots
  • Informative Point Plots
  • Bagplot with Outlier Boxes
  • Components Effect Plot
Pictures from the Gallery 6 (2021): https://community.jmp.com/t5/Discovery-Summit-Americas-2021/Pictures-from-the-Gallery-6-Select-Advan...
  • Hexagonal Map
  • Map Cartogram
  • Time Series
  • Row Ordered Spirals
  • HDR Box Plots
  • Graphlets
Pictures from the Gallery 7 (2022): https://community.jmp.com/t5/Discovery-Summit-Americas-2022/Pictures-from-the-Gallery-7-Select-Advan...
  • Dumbbell (Interval) Chart
  • Word Cloud
  • Moving Average Smoother Line Chart
  • Point Cumulative Summary Chart
  • Advanced Box Plots
  • Wind Rose Chart
Pictures from the Gallery 8 (2023): https://community.jmp.com/t5/Discovery-Summit-Americas-2023/Pictures-from-the-Gallery-8-Innovative-G...
  • Formula Based Graphs
  • Tabular Data
  • Flow Parallel Plots
  • Forest Plots
  • Percent of Factor Charts
  • Satellite Mapping
Pictures from the Gallery 9 (2024): https://community.jmp.com/t5/Abstracts/Pictures-from-the-Gallery-9-Innovative-Graph-Builder-Views/ev...
  • Super Plots
  • Swim Lanes
  • Overlay Encoding
  • Survival At Risk Plots
  • Page Grid
  • Doughnut Plots
New: Pictures from the Gallery 10 (2025): https://community.jmp.com/t5/Abstracts/Pictures-from-the-Gallery-10-Innovative-Graph-Builder-Views-2...
  • Smoother Constraints
  • Overlaid Outlined Points
  • Multiple Y Axis
  • Bump Charts
  • Vector Field Chart
  • Curved Bar Charts
Last Modified: Nov 7, 2025 8:56 AM
Comments
hogi
Level XIII
#10 - a wonderful new episode!
thanks @scwise , @Jed_Campbell
Emmanuel_Romeu
Waow, I just discovered this blog (I should have known about it sooner, thank you @Jeff upton which does an incredible job of summarizing all the amazing work you do for each new version. It deserves to be promoted more widely to our customers.
