Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Using MSA for Situations Requiring Destructive Testing
See how to:
  • Address key assumptions for MSA (Parts do not change form over time and are not changed by measuring them)
  • Overcome inability to repeat measurements when key MSA assumptions are violated
  • Perform and interpret desctructive test that assumes perfect material and likely overestimates part-to-part variation
    • Assume material within a lot or a batch is uniform
    • Gather multiple lots where each lot represents a part
    • Subdivide lots so that each subdivision will represent a repeat measurement when tested
    • Test all parts in a random order.
    • Analyze using EMP method.
  • Perform and interpret desctuctive test that assumes perfect test and likely underestimates part-to-part variation
    • Use a nondestructive test that correlates well with the destructive test
    • Build a calibration curve from destructive and nondestructive test data
    • Test parts nondestructively in a random order
    • Test parts destructively in a random order
    • Use the formula from the calibration curve to scale the nondestructive data
    • Combine results
    • Analyze using the EMP method
Notes: Questions are included at the end of the demo, beginning at ~ Time 32:30.
Resources
A reminder that to contact Jason Wiggins in comments, include @Jason_Wiggins. in your comment. Measurement Systems Analysis.zip is a zipped version of Jason's JMP 16 Project used in the session.
Comments
Also linked above but I am including it here since this post is related:
Using the EMP Method for Measurement System Analysis - JMP User Community
For those who are interested (including myself), I'm linking a Discovery presentation from Autoliv where they covered a Destructive Gauge R&R measurement example for curved data (  ) that follows the third example covered in Demast's seminal destructive Gauge R&R paper linked in this post, and recopied here: https://ibisuva.nl/assets/publicaties/artikelen/2005-demast-gauge.pdf
Thank you @Jason_Wiggins  for curating these resources and providing this wonderful presentation!
Thank you, Patrick! I am happy that you enjoyed the presentations and resources. The MSA for curve data presentation is really exciting. Destructive MSA is a solid use case for Functional Data Explorer. Enjoy!
@Jason_Wiggins Thank you,
What you can add is to produce parts with the variation you need for the MSA (like precise milled parts with varying cross-section for a tension test).
If the variation is big enough, we also pick sample within a batch or a single part in our case.
We produce for example a 10km long cable and take samples that are 2m long and further split those in 20cm sub-samples with the same "part ID" for the repeatability.
@PatrickGiuliano
The article from the ibisuva.nl page gives me an 404 error.
I found the same title under the following link: 2005-demast-gauge.pdf (ibisuva.nl)
@Mauro_Gerber Thank very much for correcting the broken link to the Demast Paper.
Thanks for the recommendations @Mauro_Gerber. Enjoy!
