JMP 16 introduces action recording and enhanced log mode to let JMP capture activities performed during an interactive session and then write the corresponding JSL code. You can also integrate this JSL into a scripted, repeatable workflow for more efficient processing of new data.
Use the Action Recorder to:
- Spend less time performing data cleanup steps.
- Interactively build a repeatable data prep workflow.
- Expand your use of JSL code using scripts generated by the action recorder.
See how to:
- Open Action Recorder by opening the Log under the Window menu.
- Captures your preparation and analysis steps as you work.
- Delete or clear saved steps. you can do that before you save the total work flow.
- Select all steps to view preview script with all the steps merged into
one script that you can save then re-run.
Resources
![action recorder.JPG action recorder.JPG](https://community.jmp.com/t5/image/serverpage/image-id/33664i204DAD431AE06904/image-size/large?v=v2&px=999)
![Action Recorder.png Action Recorder.png](https://community.jmp.com/t5/image/serverpage/image-id/33665iA5C1D3A9FAC97226/image-size/large?v=v2&px=999)
