Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
%3CLINGO-SUB%20id%3D%22lingo-sub-809943%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EDOE%20personalizzato%20specializzato%20per%20sperimentatori%20esperti%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-809943%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%0A%20%3CP%3E%0A%20%3C%2FP%3E%0A%20%3CP%3E%0A%20%20%3C%2FP%3E%3CDIV%20class%3D%22video-embed-center%20video-embed%22%3E%0A%20%20%20%3CIMG%20class%3D%22vidyard-player-embed%22%20data-type%3D%22inline%22%20data-uuid%3D%22ZPYwfhm6QaG2ehmbgogdKQ%22%20data-v%3D%224%22%20src%3D%22https%3A%2F%2Fplay.vidyard.com%2FZPYwfhm6QaG2ehmbgogdKQ.jpg%22%20style%3D%22width%3A%20100%25%3B%20margin%3A%20auto%3B%20display%3A%20block%3B%22%20%2F%3E%0A%20%20%3C%2FDIV%3E%0A%20%3CP%3E%3C%2FP%3E%0A%20%3CH4%20id%3D%22toc-hId-1423605941%22%20id%3D%22toc-hId-1424289333%22%3EScopri%20come%3A%3C%2FH4%3E%0A%20%3CUL%3E%0A%20%20%3CLI%3EAumentare%20i%20progetti%20per%20aggiungere%20vincoli%20e%20supportare%20modelli%20di%20secondo%20ordine%3C%2FLI%3E%0A%20%20%3CLI%3EMigliorare%20un%20progetto%20sperimentale%20di%20cottura%20aggiungendo%20ulteriori%20prove%20che%20escludano%20impostazioni%20estreme%20note%20per%20essere%20dannose%20per%20il%20processo%3CSPAN%3E%0A%20%20%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22txt-small%22%3E(2%3A52)%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%20Aggiungere%20vincoli%20lineari%20e%20raggruppare%20le%20nuove%20esecuzioni%20in%20blocchi%20per%20semplificare%20l'esame%20del%20progetto%3C%2FLI%3E%3CLI%3E%20Utilizzare%20Graph%20Builder%20per%20visualizzare%20la%20posizione%20delle%20nuove%20prove%20nello%20spazio%20di%20progettazione%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%20%20%3CLI%3EModella%20un%20processo%20per%20convertire%20le%20emissioni%20di%20anidride%20carbonica%20catturate%20in%20plastica%3CSPAN%3E%0A%20%20%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22txt-small%22%3E(9%3A59)%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%20Aumentare%20la%20progettazione%20per%20supportare%20il%20modello%20di%20secondo%20ordine%20adatto%20quando%20pi%C3%B9%20di%20pochi%20fattori%20sono%20significativi%3C%2FLI%3E%3CLI%3E%20Utilizzare%20l'opzione%20Limita%20per%20indicare%20che%20un%20termine%20non%20pu%C3%B2%20entrare%20nel%20modello%20a%20meno%20che%20non%20siano%20stati%20inseriti%20tutti%20i%20termini%20sopra%20di%20esso%20nella%20gerarchia%3C%2FLI%3E%3CLI%3E%20Utilizzare%20la%20regola%20di%20arresto%20per%20determinare%20se%20verr%C3%A0%20utilizzato%20il%20criterio%20informativo%20di%20Akaike%20corretto%20(AICc)%20o%20il%20criterio%20informativo%20bayesiano%20(BIC)%20per%20selezionare%20il%20modello%20migliore%3C%2FLI%3E%3CLI%3E%20Capire%20perch%C3%A9%20e%20come%20utilizzare%20la%20trasformazione%20della%20radice%20quadrata%3C%2FLI%3E%3CLI%3E%20Confronta%20i%20modelli%20originali%20e%20nuovi%2C%20quindi%20scegli%20il%20modello%20migliore%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%20%20%3CLI%3ECreare%20e%20quindi%20aumentare%20il%20progetto%20di%20emissioni%20di%20anidride%20carbonica%20da%2024%20a%2036%20esecuzioni%3CSPAN%3E%0A%20%20%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22txt-small%22%3E(19%3A00)%3C%2FSPAN%3E%3CUL%3E%3CLI%3E%20Creare%20e%20interpretare%20la%20tabella%20di%20progettazione%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%0A%20%3C%2FUL%3E%0A%20%3CP%3EDomande%20e%20risposte%20incluse%20ai%20minuti%206%3A11%2C%206%3A59%2C%2021%3A22%2C%2022%3A31%2C%2023%3A35%2C%2025%3A05%20e%2026%3A54.%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-809943%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EProgettazione%20degli%20esperimenti%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Specialized Custom DOE for Experienced Experimenters
Published on ‎11-07-2024 03:28 PM by Community Manager Community Manager | Updated on ‎04-08-2025 09:13 AM
See how to:
  • Augment designs to add constraints and support second-order models
  • Improve a cooking experimental design by adding additional runs that exclude extreme settings known to be deleterious to the process (2:52)
    • Add linear constraints and group new runs into blocks to make it easier to examine design
    • Use Graph Builder to visualize location of new trials in the design space
  • Model a process to convert captured carbon dioxide emissions into plastic (9:59)
    • Augment design to support second order model suitable when more than a few factors are significant
    • Use Restrict option to indicate than a term cannot enter the model unless all the terms above it in the hierarchy have been entered
    • Use Stopping Rule Stopping Rule to determine if corrected Akaike's Information Criterion (AICc) or Bayesian Information Criterion (BIC) will be used to select best model
    • Understand why and how to use Square Root transformation
    • Compare original and new models, and then choose best model
  • Create and then augment carbon dioxide emissions design from 24 to 36 runs (19:00)
    • Create and interpret design table
Q&A included at times 6:11, 6:59, 21:22, 22:31, 23:35, 25:05 and 26:54.
Start:
Thu, Jul 9, 2020 02:00 PM EDT
End:
Thu, Jul 9, 2020 03:00 PM EDT
Labels (1)
0 Comments
