%3CLINGO-SUB%20id%3D%22lingo-sub-816278%22%20slang%3D%22it-IT%22%20mode%3D%22UPDATE%22%3EOptimizar%20procesos%20con%20el%20dise%C3%B1o%20de%20experimentos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-816278%22%20slang%3D%22it-IT%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSPAN%3EDescubra%20c%C3%B3mo%20nuestro%20marco%20de%20seis%20pasos%20puede%20ayudarle%20a%20crear%20un%20dise%C3%B1o%20de%20experimento%20eficaz%20que%20le%20permita%20determinar%20la%20relaci%C3%B3n%20entre%20los%20factores%20que%20afectan%20un%20proceso%20determinado%20y%20lograr%20un%20resultado%20%C3%B3ptimo.%20Aprenda%20a%20describir%20su%20objetivo%2C%20especificar%20efectos%20para%20un%20modelo%20hipot%C3%A9tico%2C%20generar%20un%20dise%C3%B1o%2C%20recopilar%20datos%20de%20ejecuci%C3%B3n%20experimental%2C%20crear%20y%20estimar%20un%20modelo%20que%20contenga%20datos%20experimentales%20y%20utilizar%20estos%20factores%20para%20mejorar%20y%20optimizar%20la%20configuraci%C3%B3n.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%22%3E%3CDIV%20id%3D%22lia-vid-6316152759112w960h540r94%22%20class%3D%22lia-video-brightcove-player-container%22%3E%3CVIDEO-JS%20data-video-id%3D%226316152759112%22%20data-account%3D%226058004218001%22%20data-player%3D%22default%22%20data-embed%3D%22default%22%20class%3D%22vjs-fluid%22%20controls%3D%22%22%20data-application-id%3D%22%22%20style%3D%22width%3A%20100%25%3B%20height%3A%20100%25%3B%22%3E%3C%2FVIDEO-JS%3E%3C%2FDIV%3E%3CSCRIPT%20src%3D%22https%3A%2F%2Fplayers.brightcove.net%2F6058004218001%2Fdefault_default%2Findex.min.js%22%3E%3C%2FSCRIPT%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2F6316152759112%22%20target%3D%22_blank%22%3E(ver%20en%20Mis%20Videos)%3C%2FA%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-816278%22%20slang%3D%22it-IT%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EDise%C3%B1o%20de%20experimentos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Ottimizzare i processi con il disegno di esperimenti
Published on
11-20-2024
05:05 PM
by
| Updated on
11-21-2024
09:27 AM
Scopri come il nostro framework in sei fasi può aiutarti a creare un disegno di esperimenti efficace che ti consenta di determinare la relazione tra i fattori che influiscono su un dato processo e di ottenere un risultato ottimale. Impara a descrivere il tuo obiettivo, specificare gli effetti per un modello ipotizzato, generare un disegno, raccogliere dati di esecuzione sperimentali, creare e stimare un modello contenente dati sperimentali e a usare questi fattori per migliorare e ottimizzare le impostazioni.
Start:
Fri, Nov 25, 2022 11:10 AM EST
End:
Fri, Nov 25, 2022 12:10 PM EST
