JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, Dec. 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
We’re retiring the File Exchange at the end of this year. The JMP Marketplace is now your destination for add-ins and extensions.
Published on 11-07-202403:29 PM by
gail_massari| Updated on 04-08-202509:13 AM
See how to:
Seamlessly integrate JMP with R Projects using a handful of JSL scripting commands that allow you to connect to R, send data between R and JMP and submit R code
Add to the JMP menu a custom dialog to perform bootstrap sampling
Implement variable selection functionality in JMP using R integration, where JMP is used as a front-end and back-end to R to enhance the ease of analysis and interpretation of results
