Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
JMP and R Integration
Presented in English
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎08-26-2026 01:05 PM
See how to:
  • Seamlessly integrate JMP with R Projects using a handful of JSL scripting commands that allow you to connect to R, send data between R and JMP and submit R code
  • Add to the JMP menu a custom dialog to perform bootstrap sampling
  • Implement variable selection functionality in JMP using R integration, where JMP is used as a front-end and back-end to R to enhance the ease of analysis and interpretation of results
Start:
Mon, Sep 21, 2020 02:00 PM EDT
End:
Mon, Sep 21, 2020 03:00 PM EDT
Labels (1)
0 Comments
