Gestion des tables de données
French Mastering JMP Ouvrez la voie à une exploration de données plus rapide, plus claire et plus sûre. Structurez vos colonnes plus efficacementFiltrez vos données en toute simplicitéObtenez instantanément des insights
The content you are trying to access is permanently deleted.
Date: Friday, March 20
Time: 1:00–2:00 p.m. ET
Registration: FREE
Whether you've just downloaded the JMP 30-day free trial, are new to the software, or are returning after time away, this webinar helps you get started quickly and confidently.
This session is a great introduction to JMP for new users or a refresher for infrequent users.
In just one hour, learn how to:
Navigate the JMP data table.Reco...
Designed experiments are powerful, structured tests that reveal how your factors truly drive the responses you care about. Using Easy DOE Guided Mode, you can build and explore experiments effortlessly using an intuitive sequence of tabs, interactive profilers, and automated reports. Whether you're new to DOE or a seasoned pro, this session will give you tools to explore your processes, make infor...
JMP Student Edition has extensive regression and ANOVA capabilities implemented in an interactive, visual interface. This webinar shows you how to use JMP Student Edition to teach intermediate regression and ANOVA techniques that are covered in most courses of study in statistics, science, and engineering. Topics include: Factorial ANOVA and post-hoc tests.Multiple regression with continuous and c...
Duration: 90 minutes
Registration: FREE
Hosted via Zoom
This complimentary online workshop is designed for intermediate to advanced users with at least one year of JMP experience who would like to expand their skills in predictive modeling. Attendees learn the basics of decision tree models, also known as partition models or classification and regression trees.
If you have any questions about this e...
Do you find yourself repeatedly performing the same data analysis steps—importing, cleaning, transforming, and visualizing—every time you receive new data? Are you looking for a way to make your analyses consistent, reproducible, and easier to share with your team—without writing code? Do you want to automate and streamline your analysis process, enabling you to focus more on insight? See how to: ...
JMP Student Edition provides state-of-the-art design of experiments capabilities, including classical, algorithmic, and many specialized designs, as well as interactive tools for analysis of DOE data. This webinar shows you how to teach classical design of experiments techniques with JMP Student Edition. Topics include: Classical screening designs (e.g., fractional factorial).Classical response su...
Date: Thursday, April 9
Registration: FREE
Navigate the JMP data table.Rec...
When the data you need to analyze resides in a database, JMP provides point-and-click tools to retrieve that data simply, flexibly, and repeatably. See how to: Connect to databases via ODBC.Use the point-and-click Query Builder to import tables and perform more complex queries.Give your users the ability to specify time ranges or other subset criteria for database pulls.Connect to other data sourc...
Registration: FREE
Hosted via Zoom
This workshop is designed for intermediate to advanced JMP users who are familiar with basic statistical modeling (ANOVA and regression) and are interested in learning about design of experiments (DOE) in JMP. Attendees gain a deeper understanding of DOE through demonstrations and activities using the Custom Design platform. The workshop also c...
JMP lets you identify vulnerabilities and make reliability lifetime predictions on your products and components. See how to analyze non-repairable systems. See how to: Understand the kinds of problems are addressed by reliability tools.Consider issues addressed by reliability analysis.Understand censoring used in analysis.Plan the test.Analyze reliability with or without multiple failure causes.A...
JMP Student Edition provides state-of-the-art design of experiments capabilities, including classical, algorithmic, and many specialized designs, as well as interactive tools for analysis of DOE data. This webinar shows you how to use JMP Student Edition to teach modern algorithmic techniques for design of experiments. Topics include: Optimal designs for factor screening and response surface exper...
Date: Friday, April 24
Registration: FREE
Model validation, a method of determining if a predictive model is generalizable to new data, is critical when using models to help make decisions. Data can be partitioned into sets before modeling to avoid overfitting. Part of the original data is used to estimate parameters and the rest of the data is used to tune or evaluate the parameters. JMP Pro incorporates validation into some of its model...
Registration: FREE
Hosted via Zoom
This complimentary online workshop is designed for intermediate to advanced users with at least one year of JMP experience who would like to expand their skills in predictive modeling. Attendees learn the basics of neural network models.
If you have any questions about this event, please contact Kirsten Crannell.
Register now and start making d...
A process that is off target, too variable or out of control can result in delays, rework, or defects, which in turn often lead to higher costs and unsatisfied customers. Because of this, it’s important to understand and quantify the sources of variation within a process. See how to: Distinguish between common cause and special cause variationAssess the health of a process, whether it’s for a few ...
Sample size is a major consideration when designing experiments or other research studies, and JMP Student Edition has a suite of interactive tools for calculating sample size and power. This webinar shows you how to use JMP Student Edition to teach foundational power analysis techniques taught in design of experiments and research methods courses. Topics include: Power analysis for one- and two-s...
Date: Thursday, May 14
Registration: FREE
Registration: FREE
Hosted via Zoom
This online workshop is for beginning JMP users.
Learn how to explore and work with data in JMP through demonstrations and hands-on practices. Topics include importing data from Excel, graphical data exploration, data clean-up and manipulation, and automating processes with Workflow Builder.
If you have any questions about this event, please co...
Date: Friday, May 29
Registration: FREE
Navigate the JMP data table.Recode...
Registration: FREE
Hosted via Zoom
This online workshop is designed for any JMP user with an interest in data visualization. Only minimal experience in JMP (opening files, using menus, etc.) is required. Attendees learn about common graphs, principles of good graphs, and what to avoid.
Register now and ...
Accelerated Life Testing (ALT) is required to evaluate product reliability for parts that need to perform well for long periods. Due to low failure rates at use conditions, parts must be tested at high stress levels in order to generate failures in a reasonable amount of time. Devices requiring such reliability analyses include medical devices, semiconductor circuits, aviation equipment and more....
Date: Thursday, June 11
Registration: FREE
Registration: FREE
Hosted via Zoom
Date: Friday, June 26
Registration: FREE
Navigate the JMP data table.Recod...
