  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Creating and Using JMP 18 Platform Presets
Presented in English
Published on ‎11-07-2024 03:32 PM by Staff | Updated on ‎11-07-2024 05:42 PM
Create new JMP 18 platform presets and report customizations (including colors, axis settings, red triangle options) for an analysis to use with future launches of the same analysis platform.  Learn to create and save your own preferred configuration as a preset for any data table or set of columns.
See how to:
  • Understand presets
    • Presets are independent of a data table
    • Presets can be broadcast to other open windows using Control Key on Windows (or Command on Mac)
    • You can drag Platform Preset Icon from one window to another
  • Apply sample platform presets
  • Create your own presets
    • Create different folder levels to create a library of presets
    • Presets can capture fonts, colors, properties, red triangle options, axis settings, opening/closing outline boxes, graph sizes and more
    • Rule of Thumb: If it could be scripted, a preset will capture it
  • Share and manage presets
  • Import/export presets
  • Understand  when to use Presets, Preferences, Workflow Builder
    • Preset - reuse report customizations
    • Preferences  - specify global JMP settings
    • Workflow Builder - capture data preparation and analysis sequences
Questions answered by @wdcorley1 and @O_Lippincott at the live webinar demo.
Q: What is the relationship between global level preferences and platform presets. Does one override the other?
A: If I had preferences set globally or for a particular graph type (like font size) and also had a preset that had a different value, then the preset will  override the preference. But if I don't have a preset that includes any anything about a particular type of item (like font size), then the platform will take whatever preference I have for that item type.
Q:  Can we apply custom presets to a custom display window that  we created using JSL?
Resources
Start:
Mon, Jun 24, 2024 02:00 PM EDT
End:
Mon, Jun 24, 2024 03:00 PM EDT
Labels (1)
0 Comments
