The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Get the free JMP Student Edition for qualified students and instructors at degree granting institutions.
Automating Analyses and Reporting without Writing Code
Published on ‎11-07-2024 03:30 PM by Staff | Updated on ‎11-07-2024 05:40 PM
JMP Automation is performing a sequence of actions with one click.  Automation usually includes data import, data cleaning, and reporting and creates a routine that enables other users to perform the same work.  The workflow is also easy to modify to rerun on new data.
The manufacturing case study has 4 technicians who measure a standard part each day to monitor their measurement system. The standard part has a diameter of exactly 50 mm. Each day's measurements are recorded in the bottom row of a csv file.
The goal is to create reports saved as a JMP script (pipelinedata.jsl) and a JMP Add-In (.jmpaddin) called Measurement Report, both of which can be re-run and shared.
Video Player is loading.
Current Time 0:00
Duration 0:00
Loaded: 0%
Stream Type LIVE
Remaining Time 0:00
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
      (view in My Videos)
      See how to:
      • Understand requirements
        • Source data is consistent so one can operate on the same file each time, or use the same database query
        • Do not change important column names and data types should not be changed; however, you can update data by adding rows
        • If the automation is used by multiple users, the source data must be accessible by all
      • Find log file to make sure there is nothing in it using View>Log
      • Perform the desired work using point-and-click
        • Import CSV
        • Cleanup data - name the table; stack data format dates, create new formula column
        • Build Graph Builder and save script to log
        • Build Fit Y by X reports and save script to Log
      • Extract the script from the Log window (View > Log)
        • Remove Launch platform options from Log using red triangle >Action Recording> Platform Launch
      • Save the script to a script window from Log red triangle (Save Script>To Script Window)
      • Save the script (pipeline.jsl) to desktop
      • Exit JMP to start new session and check script by double clicking .jsl file to open and run
      • Add new row to update data table
      • Save the script to an add-in for distribution to others (File > New > Add-In) who have JMP and have access to the files in the location required by the .jsl file
      • Tips
        • Start from a fresh JMP session to avoid capturing unwanted steps
        • Many JMP platforms, especially those in the Tables menu, create data tables as output. Use the platform options to assign a name for output data tables. JMP's default names (Untitled1, Untitled2, etc.) may be unreliable in future runs.
        • Before saving the script from the log, turn off the Platform Launch steps from the red triangle menu.
        • If these requirements for simple automation are too restrictive, then it's time to learn some basic jsl coding
        • Add comments, notes to yourself to make it easy for you to remember what you did, or for someone else to interpret your work
      • To run scripts on a schedule
        • Use Windows Scheduler to launch script
        • For autorun, start script with //!
        • End script with Quit() to exit JMP
      Questions from the session answered by  Jordan Hiller @Jordan_Hiller and Christian Bille @ChristianBille.
      Q: Can I connect to MS SQL database, so I can get live data?
      A: Yes, the process would be the same. Connecting to SQL is even better as the sources stays the same. this is done through the query builder. Here is info about connecting: https://www.jmp.com/support/help/en/16.2/#page/jmp/select-tables-from-a-sql-database.shtml
      Q: Is there some info/resources on re-organizing the data,  if the source data contains multiple formats (such as transpose, making separate one column into two columns)?
      A:  Yes, here is the start of documentation you can scroll through:
      Q: Can you automate acquisition of a data set on the cloud?
      A: If the permissions are set correctly and your organization allows that, you can automate access to a shared server of any kind.
      Q: Is there a "run on open" option?
      Y: Yes, add this to your script: autorun //!
      Q: Why can't I just send the script to anybody in the organization?  Why the extra step of making in add-in?
      A: The add-in step is fully optional, but is a nice way to ensure less human error.
      Q: If you navigate to your .jsl file, is the add-in independent of that file, so that if you delete the original .jsl the add-in will still work?
      A: Yes, the script is embedded in the add-in.
      Q: Is it possible to see the backend code for an add-in?
      A: The .jsl file is included in the add-in folder.  It can also be opened and encrypted.
      Encrypting JSL fileEncrypting JSL fileEncrypting JSL file
      Q: Can I delete something from the log?
      A: Yes, highlight it in the Log, go to the Log right triangle, and then click Clear.
      Q: Can I edit the Log file?
      A: Yes, each section is delineated, and you can copy/cut and paste.
      Removing information from LogRemoving information from LogRemoving information from Log
      Q: What can I do if I know I need a minimum JMP version for my script?
      A: You can set the Minimum JMP version for your add-in and then it will only install on JMP versions that meet that minimum.
      Setting Minimum JMP Version for Add-InSetting Minimum JMP Version for Add-InSetting Minimum JMP Version for Add-In
      Q: What is the impact of the different platform preferences on the output of an analysis?
      A: The .jsl file will defer to the preferences of the person launching the script; in most cases different preferences will not break a script that is run, but the appearance of the report may look slightly different than when the script was written.
      Q: How to you get a black log?
      A: Preferences> Script Editor>Customize Styles>Theme>Dark.
      Setting Preferences for Black Background LogSetting Preferences for Black Background LogSetting Preferences for Black Background Log
      Resources
      0 Comments
