Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Accelerating Innovation Using Bayesian Optimization
Presented in English
Published on ‎10-10-2025 10:39 AM by Community Manager Community Manager | Updated on ‎11-04-2025 12:26 PM
Video using JMP 19 was posted in October 2025.
Bayesian Optimization accelerates industrial R&D and lowers the barrier to entry. It saves time and resources by learning from observed response values while using the project goals to recommend the settings to test next.
See how to use JMP Pro Bayesian optimization tools to go beyond the limitations of  traditional DOE, where augmentation is based on previous positioning of experimental points and design space optimality criteria only.
Several case studies show how to:
  • Start with some data.
  • Define goal(s).
  • Obtain model.
  • Perform a search to find next experimental data point(s).
  • Generate response for new data, update model, and repeat until satisfied.
Resources
Start:
Fri, Oct 10, 2025 08:00 AM EDT
End:
Fri, Oct 10, 2025 09:00 AM EDT
Labels (1)
1 Comment
Emmanuel_Romeu
Great video.  Amazing to see someone from the audience be able to use it after only a few minutes.
