Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Before JMP 15: You can also install a 32-bit JMP and a 64-bit JMP Pro or vice versa. But not a 32-bit and 64-bit of the same type (“JMP and JMP” or “JMP Pro and JMP Pro”)
After JMP 15: You can install both JMP and JMP Pro in the same version . Make sure you have the correct installation package (JMP vs. JMP Pro) as the default installation folder and license file will be different.
@zetaVagabond1 Yes, this is possible, unless your IT does not allow it and only rolls out one version of JMP and uninstalls the old one automatically. However, technically it is working, I have multiple versions installed in parallel.
@martindemel Thanks, Is there a link to find older versions of jmp. RN, i can only see 19.04 for downloading while some of siginificant script development work has happened in 18 and now the installer is nowhere to be found for mac or windows systems.
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
/* Re compile html */
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "This post originally written in lilicon-trans-text has been computer translated for you. When you reply, it will also be translated back to lilicon-trans-text.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/lingoTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-idea-reply-message")){
rootElement.querySelector(".lia-quilt-idea-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
}else if(rootElement.querySelector(".lia-quilt-column-alley-left")){
rootElement.querySelector(".lia-quilt-column-alley-left").appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
angular.forEach(mszList_l, function (value) {
if (document.querySelectorAll('div.lia-js-data-messageUid-' + value).length > 0) {
var rootElements = document.querySelectorAll('div.lia-js-data-messageUid-' + value);
}else if(document.querySelectorAll('.lia-occasion-message-view .lia-component-occasion-message-view').length >0){
var rootElements = document.querySelectorAll('.lia-occasion-message-view .lia-component-occasion-message-view')[0].querySelectorAll('.lia-occasion-description')[0];
}else {
var rootElements = document.querySelectorAll('div.message-uid-' + value);
angular.forEach(rootElements, function (rootElement) {
if (value == '21654' && "TkbArticlePage" == "TkbArticlePage") {
rootElement = document.querySelector('.lia-thread-topic');
/* V1.1 Remove from UI */
if (document.getElementById("tr-msz-" + value)) {
document.getElementById("tr-msz-" + value).remove();
if (document.getElementById("tr-sync-" + value)) {
document.getElementById("tr-sync-" + value).remove();
/* XPath expression for subject and Body */
var lingoRBExp = "//lingo-body[@id = " + "'lingo-body-" + value + "'" + "]";
lingoRSExp = "//lingo-sub[@id = " + "'lingo-sub-" + value + "'" + "]";
/* Get translated subject of the message */
lingoRSXML = doc.evaluate(lingoRSExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for (var i = 0; i < lingoRSXML.snapshotLength; i++) {
/* Replace Reply/Comment subject with transalted subject */
var newSub = lingoRSXML.snapshotItem(i);
/*** START : extracting subject from source if selected language and source language is same **/
var sub_L = "";
if(newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if(value == '21654') {
if($scope.sourceContent[value]){
if($scope.sourceContent[value].subject != ''){
sub_L = decodeURIComponent($scope.sourceContent[value].subject);
}else{
sub_L = newSub.innerHTML;
else{
} else {
/*** End : extracting subject from source if selected language and source language is same **/
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
sub_L = sub_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
// if($scope.viewTrContentOnly || (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase())) {
if ($scope.viewTrContentOnly) {
if ("TkbArticlePage" == "IdeaPage") {
if (value == '21654') {
if( (sub_L != "") && (sub_L != undefined) && (sub_L != "undefined") ){
document.querySelector('.MessageSubject .lia-message-subject').innerHTML = sub_L;
if ("TkbArticlePage" == "TkbArticlePage") {
var subTkbElement = document.querySelector('.lia-thread-subject');
if(subTkbElement){
document.querySelector('.lia-thread-subject').innerHTML = sub_L;
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if((sub_L != "") && (sub_L!= undefined) && (sub_L != "undefined")){
var subElement = rootElement.querySelector('.lia-blog-article-page-article-subject');
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
/* var subElement = rootElement.querySelectorAll('.lia-blog-article-page-article-subject');
for (var subI = 0; subI < subElement.length; subI++) {
subElement[subI].innerHTML = sub_L;
else {
try {
// rootElement.querySelectorAll('.lia-blog-article-page-article-subject').innerHTML= sub_L;
/** var subElement = rootElement.querySelectorAll('.lia-blog-article-page-article-subject');
for (var j = 0; j < subElement.length; j++) {
subElement[j].innerHTML = sub_L;
} catch (e) {
else {
try{
/* Start: This code is written by iTalent as part of iTrack LILICON - 98 */
if(document.querySelectorAll('.lia-quilt-forum-topic-page').length > 0){
if(rootElement.querySelector('div.lia-message-subject').querySelector('h5')){
rootElement.querySelector('div.lia-message-subject').querySelector('h5').innerText = decodeURIComponent(sub_L);
} else {
rootElement.querySelector('.MessageSubject .lia-message-subject').innerText = sub_L;
} else {
/* End: This code is written by iTalent as part of iTrack LILICON - 98 */
catch(e){
console.log("subject not available for second time. error details: " + e);
} else {
try {
/* Start: This code is written by iTalent as part of LILICON - 98 reported by Ian */
document.querySelector('.lia-js-data-messageUid-'+ value).querySelector('.MessageSubject .lia-message-subject').innerText = sub_L;
else{
/* End: This code is written as part of LILICON - 98 reported by Ian */
} catch (e) {
console.log("Reply subject not available. error details: " + e);
// Label translation
var labelEle = document.querySelector("#labelsForMessage");
if (!labelEle) {
labelEle = document.querySelector(".LabelsList");
if (labelEle) {
var listContains = labelEle.querySelector('.label');
if (listContains) {
/* Commenting this code as bussiness want to point search with source language label */
// var tagHLink = labelEle.querySelectorAll(".label")[0].querySelector(".label-link").href.split("label-name")[0];
var lingoLabelExp = "//lingo-label/text()";
trLabels = [];
trLabelsHtml = "";
/* Get translated labels of the message */
lingoLXML = doc.evaluate(lingoLabelExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
