JMPer Cable
LauraCS
Structural Equation Modeling: The arrival of a powerful new framework in JMP Pro 15
Ever wished for an intuitive and super flexible approach for specifying and fitting models? Structural equation modeling (SEM) is a framework that provides just that! Think factor analysis merged with regression, together with simultaneous estimation of numerous effects and awesome graphs.
In this post, I discuss the unique advantages of using JMP Pro for fitting structural equations models. If you’re new to SEM, be sure to check out this post, otherwise, let’s dive in!
Ease and Speed
SEM in JMP Pro is built with an intuitive user interface that enables a speedy workflow. We pride ourselves on sitting at the intersection of user-friendly and efficient; fast and replicable as coding-based tools, yet visual and simple. Importantly for SEM enthusiasts, you can do all your data cleaning, data manipulation, and model fitting, in one place.
(view in My Videos)
Model Comparisons
Best practices of SEM involve fitting multiple, competing models to data. Our platform facilitates this task by providing all the information you need from multiple models in one place. You can select which models to look at, or you can see them all at once.
Local Data Filter + SEM = Greatness
Questions such as “How do these models fit for this subset of the sample?” are important and often lead to invaluable insights, but seasoned SEM analysts have learned the pain such questions invoke. The pain comes from recognizing the amount of time needed to create new data sets and re-run all the models. In JMP Pro, the Local Data Filter will transform your pain into eagerness! In a matter of seconds, you can select the level of a variable that denotes the subset of your sample and all your models update instantly! You’ll have answers to all those insightful questions within seconds. If you’re in academia, think how much time that’ll save you in responding to reviewers’ comments. This is one of our favorite features and we can’t wait for you to try it.
(view in My Videos)
High-Quality Path Diagrams
Nobody likes to spend their time building SEM path diagrams in PowerPoint, Vizio, or any other non-statistical software. Similarly, nobody likes to use the subpar diagrams that are often produced by automated algorithms. The SEM platform in JMP Pro has high-quality, presentation-ready, appealing-to-the-eye, path diagrams. These diagrams are interactive* so you can arrange them just the way you want them (although we get them to you in pretty good shape from the get-go). Save them as a picture file and forget about busy work.
(view in My Videos)
Ongoing Error Checking
“The matrix is not positive definite” is one of numerous warning messages that SEM analysts are used to encountering when fitting complex models to data. Many times, issues are due to mistakes that are easily introduced (even by expert users) due to the incredible flexibility afforded by SEM. Unfortunately, these issues are only found after running the faulty model. The SEM platform in JMP Pro performs ongoing checks on the specification of the model to save users time and effort in tracking potential issues. The Details box gives you immediate information on the specified model and our Status tab* will let you know if you’re on the right path, the expert path, or a risky path.
(view in My Videos)
These are my five favorite reasons for using the SEM platform in JMP Pro 15. Give it a try and let us know what your favorites are! Maybe you’ll enjoy visualizing your models’ residuals, sorting results based on parameter estimates or model fit indices, or the model shortcuts. There’s lots to discover and much more to come in the new SEM platform!
*Coming in JMP Pro 15.1: model estimates on path diagram, interactive path diagram, AICc weights for model comparison, and Status tab with checks for identification rules and expanded model details.
Last Modified: Nov 25, 2019 9:20 AM
Comments
ZviLerman
Level I
Question to LauraCS or anyone in the community with experience with the SEM platform:
I am experimenting with the JMP SEM platform and I find it very useful and efficient. However, a graduate student of mine is using AMOS and, unfortunately, we are getting totally different results on the same data on the two platforms. There are huge differences in goodness of fit and in all estimates. I wonder what may be causing this. If necessary, I will gladly send the original Excel or JMP file with the data: it has 350 observations and less than a dozen variables.
Thank you in advance for your attention.
Zvi Lerman
The Hebrew University of Jerusalem, Israel
LauraCS
Hi @ZviLerman,
Glad to hear you're finding the platform useful and efficient! There are a number of reasons that could explain the differences. Please do send your data file and model to [email protected] so we can further assist you.
Best,
~Laura
ZviLerman
Level I
I have sent all the information to [email protected].
Best regards,
Zvi
LauraCS
Thanks @ZviLerman!  I was able to take a look and the models are different; the model in AMOS has more constraints than the one in JMP Pro, which explains the differences. You'll be getting more details from tech support that should help your grad student specify the same model as you are. I hope you continue to enjoy our SEM platform!
Best regards,
~Laura
ZviLerman
Level I
Thank you, Laura.
Zvi
MDM
Level I
Hi, Question for @LauraCS , is there a way to get the indirect effects in a path analysis for SEM to check if the mediation is significant?
LauraCS
Hi @MDM,
Great question! Yes, we have an option under the red triangle menu for obtaining tests for all indirect effects present in the model:
The report will list the unstandardized and standardized indirect effect(s) along with their standard error, which is based on the delta method. In the context of mediation, the SEM platform can perform currently what's known as the joint significance test and the Sobel test. Bootstrapped standard errors and confidence intervals are on the works so we'll be adding those in a future version (JSL would allow you to get these now but we want to make it much easier). Lastly, version 17.0, which will be released this October, has additional visualizations for those indirect effects.
HTH,
~Laura
