Ever wanted to automate processes and analyses? You can do it in JMP! This video shows how to automate the following steps, with a minimal amount of JSL (JMP Scripting Language) coding:
- Create a file dialog to allow you to select and open a file
- Append that data to a "master data table"
- Clean the data (using stored Recode command)
- Generate a report from the updated Master Data Table
