JMPer Cable Blog
Using the Microsoft Excel wizard
Here is a quick example of how to pull data from Microsoft Excel into JMP and then update the data. To do this, you can drag and drop the Excel file you want into any JMP window, and the Excel Wizard will appear. Next, choose the desired worksheet and the individual worksheet settings to tell JMP the row that the column headers start on, the row that the data starts on, etc.
If the results shown in the Data Preview window are acceptable, click Import and examine the resulting JMP data table. Note that two scripts appear automatically in the table panel at the upper left of the data table. These are labeled "Source" and "Update Table." From the data table, you can create a graph or analysis and save a script for recreating it to the data table.
If the data in the original file changes (maybe you get new data next week), simply click the "Update Table" script and the new data will be imported into JMP. Now, any script for a graph or analysis will incorporate the latest data.
Updating and re-creating analyses can be done easily by the click of a button!
Watch the video to see this process in action:
(view in My Videos)
Fixing misplaced Excel column headersFixing misplaced Excel column headers
Last Modified: Aug 4, 2025 1:57 PM
Comments
Ake
Level IV
The excel Wizard is super, but the Update table script should come with a warning. It deletes any formula columns created after import, which makes it difficult to use in my opinion.
hogi
Level XIII
agree, the name of the script is misleading.
"update" sounds like: "use the existing one and update it".
Not: replace the existing one with a new one.
related post:
JMP 18 new Update Table script overwrites table
Maybe improve the functionality? - or provide an option to remove the dangerous script:
Disable "Update Table" script?
Option to disable creation of "Update Table" Script
Ake
Level IV
I have actually included deletion of the 'Source and 'Update  table' scripts in automation scripts wehre I update tables, so I don't mess things up.
