  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
JMPer Cable Blog
Hierarchical Clustering, Ternary Plots, and Row State Customizations
How can you show the RGB color coordinates of crayons in an interesting way using JMP? (Image copyright James A. Alloway, Jr. Used with permission.)How can you show the RGB color coordinates of crayons in an interesting way using JMP? (Image copyright James A. Alloway, Jr. Used with permission.)
The Engineering Mailbag
Episode 2: I See Your True Colors
Every now and again, JMP Systems Engineers run into interesting questions that fall somewhat outside the typical range of JMP usage. These applications are generally clever and bring home how using data isn’t just for business or technical problems. Below is an example from another colleague from New York state that I thought would be fun to share.
Jim was trying to analyze the data on 150 Crayola crayons as part of some volunteer work. He hoped to show students cool data visualizations that would spark their interest in STEAM (Science, Technology, Engineering, Art & Design and Mathematics).
The Question
Hi, Mike [JMP],
I've finally got a question for you. I'm creating a data set for a STEAM presentation. For the Art & Design part, I have data on Crayola crayons (150 rows). I am trying to create a ternary plot using the color coordinates (R,G,B), which I have for each row (color). I can create the plot without difficulty, but I want to have each marker on the plot be the actual color represented in each row. I've been able to do this by hand, but I assume there must be an easier way (without having to write a script).
Any guidance in this direction would be appreciated! (There is no rush at this point.)
Thanks.
Jim [User]
My Response
Try this out.
<data table attached>
Well … that was an informative exchange, wasn’t it?
This is an example of one of those rare cases where the only way to show someone how to do something is to actually do it for them. I’m generally not a fan of doing this, but sometimes that's the best way. And yes, in this case, the answer is a script. Let’s take a second and walk through the data and what I did. The data Jim provided (available here) looks like this:
Jim's original data tableJim's original data table
What we see are columns for the crayon name and the HSV RGB coordinates for that color. I didn’t actually use the HSV coordinates for my solution. Jim would like to figure out a way to programmatically assign a color to the row state that matches the color described by the RGB coordinates. (If that sounds complicated, just hang on – it’s not that bad.) Here’s the data table I sent back:
My data tableMy data table
Note the table scripts that I included (next to the green arrows on the left). The first one is where the magic happens. The others are some fun analyses that I’ll talk about later.
Well, Tickle Me Pink!
First, let’s look at this coloring business. Depending on what you are trying to do, JMP needs the RGB coordinates to be formatted differently. Working with the cell colors (the backgrounds of the color names in the columns) and the row state colors requires RGB to be scaled between 0 and 1. So, because I was trying to be transparent with what I was doing, I created a set of columns (Red, Green, Blue) to rescale the RGB coordinates from the 8-bit color scale (0-255) to between 0 and 1. The Table Script, “Color Cells,” then does two things. First, it goes through each row using a For Each Row() loop and the :Color Name << Color Cells() message to set the cell colors. Then, again for transparency (and probably because I did this over the course of a couple of days – I can’t remember which, to be honest), I used a second step involving a For() loop to set the row states using the columns I created.
Names Default To Here( 1 );
dt = Current Data Table();
dt << Clear Select;
For Each Row(
       // get RGB values
       red = Column( "Red" )[Row()];
       green = Column( "Green" )[Row()];
       blue = Column( "Blue" )[Row()];
       // color the "sample" column cell with the sample color
       :Color Name << Color Cells( RGB Color( red, green, blue ), Row() );
For( i = 1, i <= N Rows(), i++,
       // get RGB values
       red = Column( "Red" )[i];
       green = Column( "Green" )[i];
       blue = Column( "Blue" )[i];
       dt << Select Rows( i );
       dt << Colors( RGB Color( red, green, blue ) );
       dt << Clear Select;
Running this script creates the colorful table I sent back to Jim.
Now, while this table is quite colorful, consuming this kind of data really begs for some powerful visualizations. Since RGB is a ternary coordinate space, a Ternary Plot seems like an appropriate starting place:
 A Ternary Plot is a good place to start.A Ternary Plot is a good place to start.
The row state coloring provides a clear picture of where each crayon sits in the RGB color space. I should also point out there is a little bit of a caveat emptor on the use of Ternary Plots for this application. Strictly speaking, the Ternary Plot platform expects the three values provided for each coordinate to sum to 1. When the data provided doesn’t meet this criterion, it normalizes the data points so they do. So, while the Ternary Plot is really neat, it’s not a 100% accurate representation of the color space. However, since the point of the exercise was to produce some graphics that would excite STEAM interest, I think trading a little accuracy for visual impact is OK…
Analytically, it’s possible to group the crayons based on how similar their colors are using a Hierarchical Clustering. Here, I’ve shown the Constellation Plot, which is my favorite way of looking at a dendrogram, from running Hierarchical Clustering on the RGB space coordinates:
A Constellation Plot produced by performing Hierarchical Clustering on the data.A Constellation Plot produced by performing Hierarchical Clustering on the data.
From this, I can see that there are somewhere between 5 and 7 groups of colors. I set the number of clusters to 5 and then looked at the parallel plots. The differences in the clusters are easily seen, as are the similarities within the clusters. I found it interesting that the pastel and day-glow colors were put into their own clusters (clusters 2 and 3).
The pastel and day-glow colors were put into their own clusters (clusters 2 and 3).The pastel and day-glow colors were put into their own clusters (clusters 2 and 3).
You can see similar results with the k-Means clustering script.
Postscript
As always, revisiting something after putting it down for a while provides a new perspective. I’ve revisited this data set a couple of times since Jim originally reached out. What can I say? I’m a nerd, and it’s a fun little data set to play with. First, in the process of writing this post, I realized I made this code much more complex than I needed to. The entire coloring operation could be done using a single For Each Row() loop. I can also simplify the coding by creating a list and transforming the list to get the coordinate set JMP needs without creating new columns.
dt << Clear Select;
For Each Row(
       // get RGB values
       r = Column( "R" )[Row()];
       g = Column( "G" )[Row()];
       b = Column( "B" )[Row()];
       rowVal = {r, g, b};
       // create a scaled set of colors
       rowValS = rowVal/255;
       :Color Name << Color Cells( RGB Color( rowValS ), Row() );
       // apply a row state to each row
       dt << Select Rows( Row() );
       dt << Colors( RGB Color( rowValS ) );
       dt << Clear Select;
Next, I really liked the Ternary Plot from Jim’s original data set (issues with accuracy aside). It got me thinking about what would happen if I generated a space-filling example that would map out all the combinations in the RGB space. The script I came up with is fairly complex. I uploaded it to the File Exchange as RGB Color Space Mapping if you want to have a look. Regardless… the Ternary Plot it produces is pretty impressive. In retrospect, maybe I should have titled this post “Dark Side of the Moon."
This is what happened when I generated a space-filling example that mapped out all the combinations in the RGB space.This is what happened when I generated a space-filling example that mapped out all the combinations in the RGB space.Editor's note: Have you read the first installment in our Engineering Mailbag series? See how Mike helps a user who was using JMP to decide whether to sign up for a snow removal service.
A Note From The Author
For those of you reading this again, no you’re not crazy, the title did change a little.  I received a request to update the title so that it would be easier for our search engines to find.  I can only guess this is because some search engines are modern incarnations of 19th-century reference librarians with no sense of humor.  Apologies for any inconvenience.  -M
Last Modified: Jul 2, 2018 3:27 PM
Comments
arati_mejdal
Level XI
Very cool graphs!
