Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
It is unclear what the request is for this Wish List item. Can you provide more detail on what you are asking for? An example and a use case would be helpful.
