%3CLINGO-SUB%20id%3D%22lingo-sub-255641%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3Esuggestions%20for%20profiler%20in%20parametric%20survival%20platform%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-255641%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EI've%20encountered%20two%20issues%20with%20the%20quantile%20profiler%20(which%20might%20be%20related).%20When%20the%20model%20is%20modified%20the%20axis%20settings%20and%20the%20axis%20label%20are%20reset%20to%20default.%3C%2FP%3E%3CP%3EI'm%20looking%20at%20data%20that%20is%20normally%20plotted%20on%20a%20logarithmic%20scale%20and%20where%20lifetime%20is%20counted%20in%20%22numbers%20cycles%22%20rather%20than%20time.%20It's%20quite%20annoying%20that%20every%20time%20the%20model%20is%20changed%2C%20the%20quantile%20profiler%20resets%20the%20axis%20scaling%20to%20%22linear%22%20and%20the%20axis%20title%20to%20%22time%22.%20It%20would%20be%20helpful%20if%20that%20could%20be%20changed.%20(I%20didn't%20find%20a%20means%20to%20change%20that%20behaviour%20in%20the%20preferences.)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-255641%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EUser%20Interface%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
suggestions for profiler in parametric survival platform
I've encountered two issues with the quantile profiler (which might be related). When the model is modified the axis settings and the axis label are reset to default.
I'm looking at data that is normally plotted on a logarithmic scale and where lifetime is counted in "numbers cycles" rather than time. It's quite annoying that every time the model is changed, the quantile profiler resets the axis scaling to "linear" and the axis title to "time". It would be helpful if that could be changed. (I didn't find a means to change that behaviour in the preferences.)
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
