Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Hello, thank you for the request! Can you provide an example of what you would like to see in Graph Builder? Also, we would suggest using Fit Y by X if you would like additional least squares regression options.
