%3CLINGO-SUB%20id%3D%22lingo-sub-627454%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EStandard-Regression%20mit%20kleinsten%20Quadraten%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-627454%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3E%3CSTRONG%3EWas%20hat%20Sie%20zu%20dieser%20Wunschliste%20inspiriert%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EWelche%20Verbesserung%20w%C3%BCrden%20Sie%20gerne%20sehen%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%3CSTRONG%3EWarum%20ist%20diese%20Idee%20wichtig%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3CP%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-627454%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EMassenanpassung%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-627549%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Standardregression%20der%20kleinsten%20Quadrate%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-627549%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EWas%20ist%20das%20Problem%20mit%20dem%20aktuellen%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-627568%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Standardregression%20der%20kleinsten%20Quadrate%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-627568%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EDie%20aktuelle%20lineare%20Anpassung%20im%20Graph%20Builder%20hat%20nur%20die%20Option%20f%C3%BCr%20partielle%20kleinste%20Quadrate%2C%20keine%20totalen%20kleinsten%20Quadrate.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-628985%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EBetreff%3A%20Standard-Regression%20der%20kleinsten%20Quadrate%20in%20Graph%20Builder%20-%20Status%20ge%C3%A4ndert%20in%3A%20Needs%20Info%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-628985%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EHallo%2C%20danke%20f%C3%BCr%20die%20Anfrage!%20K%C3%B6nnen%20Sie%20ein%20Beispiel%20daf%C3%BCr%20geben%2C%20was%20Sie%20in%20Graph%20Builder%20sehen%20m%C3%B6chten%3F%20Au%C3%9Ferdem%20empfehlen%20wir%20die%20Verwendung%20von%20Y%20nach%20X%20anpassen%2C%20wenn%20Sie%20zus%C3%A4tzliche%20Regressionsoptionen%20der%20kleinsten%20Quadrate%20w%C3%BCnschen.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-629339%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EBetreff%3A%20Standard-Regression%20mit%20kleinsten%20Quadraten%20im%20Graph%20Builder%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-629339%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3Eger%C3%BChrt.%3C%2FP%3E%3C%2FLINGO-BODY%3E
standard least squares regression in Graph Builder
Why is this idea important?
4 Comments
hogi
Level XII
What ist the issue with the current one?
CasualUsers
Level I
The current linear fit in graph builder has option for partial least square only, no total least square.
Status changed to: Needs Info
Hello, thank you for the request! Can you provide an example of what you would like to see in Graph Builder? Also, we would suggest using Fit Y by X if you would like additional least squares regression options.
hogi
Level XII
moved.
