options for "order by" in Graph Builder
☐ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
In Graph Builder, if there are nominal values on an axis, you can use the 'Order by' option to select another column or count to specify an order.
This option is available if multiple columns are nested on the axis, but it's unclear how the values are sorted.
Even worse: the behavior changed from JMP18 to JMP19.
-> Plots look very different now, scripts have to be adjusted.
the examples below are from Graph Builder - Order by , with main category "age" and subcategory "student"
JMP19: values are sorted, ignoring the categories on the axis. Then the axis labels are added.
Therefore one age group  (e.g. 14) can show up multiple times:
< JMP19: The values are sorted for each category (ignoring the other categories).
- age sorted by age, ignoring student names
- students sorted by name, ignoring age
-> Robert is twice in the data set. The position of Rober#1 and Rober#2 is determined by mean(Rober#1 / Rober#2)
-> Rober#1 comes later than expected, Rober#1 comes earlier than expected / height jumps
1) Please add an option to specify how sorting works if multiple columns are nested on an axis.
2) Please add a new mode:
- main categories are sorted by averaging the respective entries (like in JMP 18)
- subcategories are sorted by their order WITHIN the parent category.
e.g.
For Big Class, the proposed mode is similar to the mode used in JMP18.
Find Robert to see the difference.
View more...
New Column( "myOrderBy",
	Formula( Col Mean( :height, :age ) * 10000000 + :height ),
) << run formuals();
Graph Builder(
	Variables(
		X( :age, Order By( :myOrderBy, Ascending, Order Statistic( "Mean" ) ) ),
		X(
			:age_name,
			Position( 1 ),
		Y( :height )
	Elements( Bar( X( 1 ), X( 2 ), Y ) )
Why is this idea important?
- backward compatibility
- For many applications, it makes the most sense for subcategories to be sorted by order within the parent category.
2 Comments
hogi
Level XIII
Are there additional modes which should be added?
Sarah-Sylvestre
Level V
Thank you for sharing this feedback!
