Hello @hogi! We are still evaluating your request and I will let you know when we have an update. In the meantime, I wanted to share that you can put the title above the gradient by using the legend title, which would save you some space. I'm betting you are probably already aware of that, but just wanted to share in case.
Hello! Thank you for submitting this request. We do not plan to implement this request at this time, but I will update this wish if it becomes a priority.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
