Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Hello @hogi! We are still evaluating your request and I will let you know when we have an update. In the meantime, I wanted to share that you can put the title above the gradient by using the legend title, which would save you some space. I'm betting you are probably already aware of that, but just wanted to share in case.
Hello! Thank you for submitting this request. We do not plan to implement this request at this time, but I will update this wish if it becomes a priority.
